Vapor Canister?
Vapor Canister?
Does anyone know where to find a new vapor canister? I think thats what its called. I need that black canister that sits on the driver side, right by the radiator. If anyone knows where to get one, or if I even need it, please let me know! Its greatly appreciated, thanks.
Unless you need it to pass vehicle or DEQ inspection, it's not a necessary item to make your car run well. It simply is a way to catch vapors and return them to the fuel tank. Took mine off my '71 back in '73 when I bought it, as it was a Ca. item, and not required in other states at that time.
Since I've never had my tank out I simply plugged the line where it came off the tank above the axle. Then I changed to a vented gas cap. That's all it took to work great.
