Tunnel Ram Setup
Old 02-20-2011 | 05:16 PM
Bad_Z28's Avatar
Here are some pics of the pump...
  #72
Old 02-20-2011 | 05:17 PM
Bad_Z28's Avatar
My camera sucks with the up close stuff. had two more but they are blurry too...
  #73
Old 02-20-2011 | 07:55 PM
That's OK! It's easy to see it's a 30cc pump. The bowl thickness appears to be the same as the flange area where the screws go. The 50cc pumps have deeper bowls and appear thicker than the flange area.
Wish I had checked Ebay and found those kits you linked before I bought mine from Summit! I paid twice that for my kits!
  #74
Old 02-21-2011 | 03:13 PM
Bad_Z28's Avatar
OK... Got the pumps ordered today. Got my bracket for the Y block will post pics when I can.
  #75
Old 02-24-2011 | 07:06 AM
Bad_Z28's Avatar
Well this weekend should be productive. I hope to have the 50cc pumps. and a new speed-O cable because I removed the cruise control unit. My girlfriend's brother has a hood that he had in the back of his shop that he is donating to the cause. Free is really nice...lol
Decided to go with two push-in breathers instead of running a pcv valve. Any thoughts on this idea??? Will re-think it if it starts making a mess of things.
Things to do.....
Route fuel lines from carb's to pump.
Install Lokar throttle cable.
Install Lokar kick-down cable.
Replace lower heater hose.(yuck)
Wire up coil and distributer.
Install 50cc pumps.
Install speed-O cable.
Run vacuum lines for booster,modulator and hvac.
Change oil (w/additive)
Fire this baby up...
Should **** my neighbors off running the car @2000 rpm for 20 minutes or so,since the car has 3inch exhaust with Dynomax race bullet mufflers(if you want to call them that)
Will update the thread with pic's and info. And probably a couple questions I would venture to say.....
  #76
Old 02-24-2011 | 08:09 AM
Sounds great to me. I eliminated my PCV valve also and went with 2 breathers. So far it's been fine.
  #77
Old 02-24-2011 | 10:18 AM
You're way better off with one PCV valve in one cover, and one breather in the other. The PCV will suck out the crankcase venting as opposed to the engine having to push it out the breathers, which makes it easier on the engine and seals. Plus, the circulation of air through the crankcase helps to pull moisture out, which extends the life of your oil, and in turn, your engine. Leave it connected.
  #78
Old 02-27-2011 | 07:59 AM
Bad_Z28's Avatar
Got the 50cc pump's installed...
Got the fuel lines made and ran. Here are a few pic's of the Y block mounting...
Got the heater hose replaced and the vacuum line for the booster and stuff. finished the plug wires except the coill wire.
Got the throttle cable installed but it seems like it is not pulling straight from where it goes through the firewall. May have to do some tweaking to the pedal or the mounting position...
Going to wire the coil and distributor today. Straighten out the throttle cable issue. Install the kick-down cable. Get fluids in it and hope to fire it up......
  #79
Old 02-27-2011 | 09:25 AM
gfrench's Avatar
Looks great, wish my engine was that pretty.
  #80
Old 02-27-2011 | 05:24 PM
Bad_Z28's Avatar
Well... I think the throttle is had to push do to the rod that connects the carbs together... I think there should be some sort of bushing or washers on the linkage that isn't there. It is not to bad but would be on a long drive.....I got the ignition all wired up and mad the new coil wire. change the fluids and tried to fire it up....What do ya know...SHE RUN'S.....
Here is a video if it works....Got the cam broke in and the she is runnin pretty good with not many adjustments....
http://s306.photobucket.com/albums/n...urrent=016.mp4
Quick Reply: Tunnel Ram Setup
