what cam to use in a zz4 small block
Old 07-05-2015, 10:19 PM
Craig Ferguson's Avatar
Default what cam to use in a zz4 small block
I have a 350 zz4 that I suspect has a flat cam due to poor performance and backfiring through the carb an exhaust. I will be checking the rocker arm lift on all valves to determine what the cam looks like but if I need to replace the roller cam I am not sure to just get a GM replacement ZZ4 cam and lifters and assume GM has the best street performance cam out there or does anyone have a better selection or idea that would be a good street cam to perform up to about 6,500 RPM with a 5 speed. I am also wondering if I should stay with hyd roller or go to a solid roller cam.
Old 07-06-2015, 07:00 AM
YAV8's Avatar
It would be unusual for a hyd roller to go bad. Or some one did swap out the cam for a flat tapped. Check the rockers to see of all are working and if they are start looking at plug wires and distributor as the problem. Do the simple thing first.
snopro_16
67-69 V8 Tech
14
08-23-2022 04:08 PM
decaen
02-16-2012 01:08 AM
gadmhahn
10-09-2009 09:20 PM
acarius
04-07-2009 05:53 PM
Carinhas
67-69 V8 Tech
13
08-23-2007 05:02 PM
Quick Reply: what cam to use in a zz4 small block
