Engine Oil Leak
Old 05-10-2015, 07:50 PM
wlbuckles's Avatar
Default Engine Oil Leak
Have dripping oil leak near rear of motor when in idle mode. Tend to think a leaking rear seal. Any Help ? Thanks.
Old 05-11-2015, 05:45 AM
flat tire's Avatar
make sure it is not from the back of the valve cover or the intake running down behind the block
if it is your rear seal remove the pan or pull the engine (depending on type of oil pan you have) and replace
Old 06-29-2015, 03:37 PM
20redfrogs's Avatar
It could be from the oil sending unit near the distributor.
Old 07-01-2015, 08:14 AM
flynbyu2's Avatar
That rear main seal is no fun to replace.
I hope it's just a pan gasket.
Chinook311
02-01-2010 11:28 AM
Brett12345
01-16-2010 04:03 AM
g3mini609
12-26-2009 06:21 AM
CNCman
10-22-2009 08:29 AM
ChaoticBastard
05-09-2006 02:01 AM
Quick Reply: Engine Oil Leak
