brake mount ????????? auto to manual
I have a 1967 camaro and it was originally a 4 speed car. When I bought the car, it had no pedals or mounting brackets. I purchased a clutch/brake pedal kit from classic industries but they do not sell the mount bracket. This is the braket that the pedals mount to that go through the firewall and the booster mounts to it. I am trying to find out if the auto trans brake pedal mount will work with a brake/clutch pedal swap in? Also, does anyone know what years this mount was used? I have a mount unit from a 1980 Z28 Automatic. Any help would be greatly appreciated. Thanks. P.S. there is a mount bracket on ebay that is from a 1967 auto Camaro.
RE: brake mount ????????? auto to manual
The auto unit will accept the clutch pedal. The provision is there to pass the clutch pedal pin through the pivot point for the brake. If you cannot find anything I have a complete setup from a 68 RS, should be identical.
