Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
Warped fenders?
Old Oct 2, 2008 | 09:05 PM
DMateo's Avatar
Default Warped fenders?
As you can see in these pictures, my fenders are not completely aligned with the doors. It's not as bad on the driver's side, but it's there on both sides. Has anyone else had this happen, and does anyone know how you can tweak them? I've heard it is normal warping that can happen with age.
Old Oct 2, 2008 | 09:17 PM
02StanGT's Avatar
Default RE: Warped fenders?
I think you can go underneath and bend where it is connected back inwards. I have seen something on this in another forum, and I am trying to find it real quick.
Old Oct 2, 2008 | 09:18 PM
02StanGT's Avatar
Old Oct 2, 2008 | 10:46 PM
DMateo's Avatar
Thanks for the link will see what I can do, you're a big help
Old Oct 3, 2008 | 11:06 AM
The front fender is made of plastic, so you can unbolt the bottom part and move it inward, and bolt it back down. You may have to elongate the holes if there is not enough movement allowed.
Old Oct 13, 2008 | 08:38 PM
DMateo's Avatar
It worked! Thanks guys, apparently whoever had it before me drove it over something, cause the bracket underneath was kinda screwed up
Old Oct 13, 2008 | 10:10 PM
02StanGT's Avatar
Looks like you did a good job. It gets messed up if you use Chevys 'jacking' points.
beckler
Sep 15, 2011 11:19 AM
BigMike95Z28
Jun 27, 2010 11:46 AM
xxRONNIExx
Jun 15, 2009 10:10 PM
zerokool91
Feb 15, 2008 09:34 PM
