Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
paint
Old Feb 19, 2007 | 01:28 PM
97BAMF's Avatar
Default paint
i was wondering about painting my car but i did not know if i should just paint the outside or if i should peel everything off and paint the entire car again. and if i were to do that would anyone happen to know how much it would cost and how long it would take?
Old Feb 19, 2007 | 05:02 PM
badinfluenceRS's Avatar
Default RE: paint
what would you 'peel' off? exterior trim?
Old Feb 19, 2007 | 05:23 PM
74454bb's Avatar
May 2007 ROTM
Default RE: paint
If you don't know then it would be cheaper to have a shop do a paint job. If you paint your car right it will run anywhere from 300 to 1500 depending on the paint and supplies you get. There is alot more to it then just spraying over the old paint. As far as time, it would take you alot longer to get it the way you want it if you havn't done a car before.
Old Feb 19, 2007 | 10:30 PM
97BAMF's Avatar
Default RE: paint
i'm sorry ididn't mean to say peel i meant like pull everything out of the car including the motor and actually paint everywhere that there was paint
Old Feb 19, 2007 | 11:08 PM
74454bb's Avatar
May 2007 ROTM
Default RE: paint
you wouldnt have to pull the motor,just the outside trim,and the trim around the door openongs. Everything else would be taped off and plasticed.It would be a good idia to take the door panels off.
Old Feb 21, 2007 | 08:23 PM
97BAMF's Avatar
Default RE: paint
thanks man i think i am going to do that
Old Feb 21, 2007 | 09:04 PM
MadMikeZ28's Avatar
Default RE: paint
You want a nice job and the door jambs painted. Pull the stuff off yourself to save the labor cost of that. You want your engine comprtment painted and looking factory new. Pull your motor. You want just to refresh it and make it shine again. Pull off you extrior trim and door handles and what ever does not get painted and take it to a body shop to paint it. Doing that kind of work yourself will save you that labor cost but if you scratch it putting it together its on you, not the shop.
Old Mar 12, 2007 | 12:51 AM
1969 SS's Avatar
Default RE: paint
as an ABSOLUTE minimum, you want to take everything off the outside of the car that can be removed (window molding, lights, door handles and door locks, trim moldings, gaskets and weatherstripping). taping off stuff is saved fo rcheap paint jobs
supplys for a good job are going to be hundreds of dollars alone. the clear on my car was over $300.00 a gallon and that was 4 years ago.
if you've never had any experience with this and don't have the place to do it or someone local to help you out if you get stuck, I'd leave it to the pros
67 455 Bird ragtop
Jan 19, 2011 07:57 AM
Mraktos
Apr 2, 2008 12:34 PM
purpl96
Oct 25, 2007 04:07 PM
jdubs1813
Apr 27, 2007 04:23 PM
Tarsis
Apr 22, 2007 10:57 PM
