Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
flat tire during cold snap
Old Oct 20, 2009 | 10:40 AM
oh yah u will find it now.
Old Oct 20, 2009 | 10:58 AM
Overnight isn't all that long, you should be able to see bubbles. Stick it in the bath tub.
Old Oct 20, 2009 | 11:24 AM
kyphur's Avatar
You really want my wife to kick my *** don't you?
Old Oct 20, 2009 | 12:31 PM
Don't do it when she's in the tub! Create a diversion and sneak it in.
Old Oct 25, 2009 | 09:15 AM
kyphur's Avatar
Found the leak and fixed the rim yesterday. I found it was coming out around the rim's edge in two places so I pulled the valve stem core and let the air out. Took my rubber tipped pry bars and gently pulled the tire back. In one spot there was a small bar code sticker that was bunched up on itself and looked water damaged. Pulled that out, put in a small amount of gorilla snot (to both leak areas) and pumped the tire back up. Been holding air overnight so far (well past the normal life expectancy with the temp dropping again into the 50's last night) and I'll check later this afternoon when I get back home.
1990CamaroRS
Jul 24, 2012 03:38 PM
navyman85
LS Series Tech
10
Feb 24, 2010 10:52 AM
golfvette
Nov 1, 2007 06:25 PM
