VS Cars going head to head!
LS1 Camaro Z28 vs. LS2 GTO
Old Apr 18, 2007 | 07:32 PM
Deagle85's Avatar
Default LS1 Camaro Z28 vs. LS2 GTO
Who would win from a dig and a roll in a street race?
Whats the difference in appearance between the ls1 and ls2 gto's? is it simply the 5.7 and 6.0 badges?
Old Apr 19, 2007 | 12:13 AM
coprunr's Avatar
Default RE: LS1 Camaro Z28 vs. LS2 GTO
the LS1 GTO had a flat hood , and both exhaust tips are on the left side of the car , the LS2 GTO has scoops on the hood and the exhaust is split , has one pipe on each side. an LS1 car you should be able to take if you can drive . an LS2 car you would probably be able to get or at least run very close if you run from a dig because the IRS isn't the greatest for traction off the line , but they will jump pretty good from a roll....they weigh about the same as your car , same tranny , but an extra 70hp....
Old Apr 19, 2007 | 05:02 PM
Deagle85's Avatar
oh ok, i understand and that makes sense. I've seen a few ls2's runnin around here. Just heard they weren't all that fast compared to the numbers they put out. hmmm
Old Apr 19, 2007 | 05:50 PM
Hisss04Cobra's Avatar
I'm pretty sure they are fat pigs, and weigh close to 3800ish lbs.
Coupe
3725http://ultimategto.com/cgi-bin/stats...&f1=weight
Old Apr 19, 2007 | 05:51 PM
From a dig you might pull a little, but it should pull back and it be even.
From a roll it should beat you.
Old Apr 19, 2007 | 05:54 PM
Deagle85's Avatar
Gotcha, I figured that was probably what would happen Hiss, thanks. Buncha military dudes around here rollin around in Lancer EVO's, STI's, LS2 GTO's, Chargers... these are just young kids in the military too. They don't do anything but put money into their cars, its crazy
So what about an evo and an sti? I know they'd get me from the dig cause of AWD, but from a roll?
Old Apr 19, 2007 | 05:58 PM
They lose massive amounts of power through the drivetrain, since they are AWD.
A dig they should destroy you...if they can drive.
But you will eventually catch up them, on a stock for stock race.
Your ls1 has very good top end power, so a roll should be no problem, and you would dominate them.
Old Apr 19, 2007 | 06:03 PM
Deagle85's Avatar
Cool, cool. Around here there really is no place to race from a dig cause I live in a small town so everything is 2 lane roads. I guess I look to the roll on more than anything since the highways around here are really the only place to race, unless someone really wants to be an idiot and pass on a 2 lane road downtown. After learning this I'd actually like to pull up behind an sti or evo on the highway hehe
So are the STI and EVO about the same? from a dig and a roll?
Old Apr 19, 2007 | 06:06 PM
Yes,
They are have around the same hp/tq and they are both awd.
I'm not an import guru so I'm not exactly sure of their hp/tq.
Old Apr 19, 2007 | 06:11 PM
Deagle85's Avatar
I'm definitely no import guru myself, frick an import... unless its a supra the only import I do like
How bout a stock for stock 02 Z28 and an 02 GT Mustang. From a dig and a roll
