VS Cars going head to head!
killed an honda accord and mitsubishi 3000gt
Old Apr 13, 2008 | 11:57 PM
  #31
SpecterGT260's Avatar
Ninja Administrator
Default RE: killed an honda accord and mitsubishi 3000gt
IBTL! [&:]
Old Apr 14, 2008 | 12:02 AM
  #32
BigNic's Avatar
4' 11" 117 lbs of fury!
blt?
Old Apr 14, 2008 | 12:04 AM
  #33
Ninja Administrator
it means in before the lock. they use it in just about every one of their street/strip threads at mustangforums.
Old Apr 14, 2008 | 12:11 AM
  #34
BigNic's Avatar
i guess that kinda speaks to the validity of the mustangers posts ......but mine was BLT which means bacon lettes and tomato....
Old Apr 14, 2008 | 02:28 AM
  #35
carguy_z28's Avatar
ORIGINAL: BigNic
MMMMM......... B L T.... I want one now...lol....... Doesnt change the fact.... lock the thread...we'll start another one!!! LMAO kidding...
Old Apr 14, 2008 | 06:21 AM
  #36
3000gtsrock's Avatar
alrite RETARDS when the hell did i ever say that the stealth/3000gt wasnt the same car despite the few cosmetic exterior changes? here you go *** read it all you want http://www.mitsubishiforum.com/models/3000gt/
*From 1991 until 1996 a 3.0 L DOHC 24-valve V6 engine with a 10.0:1 compression ratio powered the 3000GT. That engine produced 222 hp at 6000 RPM. From 1997 to the end of its production in 1999 the 3000GT used a 3.0 L SOHC 12 valve V6 at only 89:1 compression ratio. This model only produced 161 hp at 5500 RPM and was considered a disgrace to the previous models. Base models of the 3000GT were equipped with a manual 5-speed transmission with standard overdrive or an automatic transmission, which also had overdrive. The 3000GT had front wheel drive and an independent front suspension system and a multi-link rear suspension.*
Old Apr 14, 2008 | 07:46 AM
  #37
Ninja Administrator
u know guys, the numbers straight from GM say the z28 from 98-02 had ~305hp. just a thought to consider when quoting factory specs
Old Apr 14, 2008 | 09:47 AM
  #38
95slvrZ28's Avatar
3000gt, I would suggest that you tread lightly with insulting members, that usually doesn't play out too well...for you.
Good discussing = [sm=type.gif]
Insults = [sm=lockeddance.gif]
Old Apr 14, 2008 | 10:01 AM
  #39
BigNic's Avatar
1.thank you for finally provideing some kind of source for your claim....
2. that is a forum thusly is opinion based
3. while that info may or may not be accurate there is not anything confiming the info other that the belive in the propriater of the forum
4. no need to cus at me man just becuse you cant debate properly....
Old Apr 14, 2008 | 10:43 AM
  #40
carguy_z28's Avatar
ORIGINAL: BigNic
lmfao!!! Its ok bigNic, he's probably only in grade 4, he hasnt learned how to debate yet...
