VS Cars going head to head!
camaro vs. audi s4 hahha
Old 02-01-2009 | 11:12 PM
95slvrZ28's Avatar
Spec, it has AWD...we all know that gives you the most massive advantage in the world. If it has AWD, it's obviously faster than any stupid RWD piece of crap right. I mean...top fuelers run AWD right?!?
  #52
Old 02-01-2009 | 11:41 PM
Saint_Ali's Avatar
im thinking about converting my camaro to awd so i dont get raped by these v dubs all the time
  #53
Old 02-02-2009 | 12:49 AM
95slvrZ28's Avatar
That's a good idea, I highly recommend swapping out your V8 for a 4 cylinder as well, it will weigh less.
  #54
Old 02-02-2009 | 03:15 AM
cbr600rx7's Avatar
Thanks for the advice. I will start tearing out the LS1 right now. I think a Honda B16 swap would be the way to go. I mean it is a lot lighter and i can turn like 8000RPM's and make like 140 torque. Buts its all about the power weight ratio right.
  #55
Old 02-02-2009 | 09:20 AM
SpecterGT260's Avatar
Ninja Administrator
NO CBR BAD!
what a dumb comment!!!!!!!!!!
its not power to weight RATIO.... if you use the word ratio then you have to actually compare the two numbers to see how they work out. instead we just arbitrarily shout "power to weight!" after every argument, and in so doing we can ignore the fact that a 350hp 3300lbs stock ls1 fbody has a better ratio than a 220hp 2800lbs civic H22 swapped civic. or hell, lets even give him the 220hp in the 2200lbs 80's hatch. 350/3300 > 220/2200.
  #56
Old 02-02-2009 | 10:58 AM
cbr600rx7's Avatar
LOL some one else gets it. So i am not alone.
  #57
Old 02-02-2009 | 11:24 AM
1990CamaroRS's Avatar
Fancy Sparkle
maybe i should get an intake, 4" turbo back, swap the wastegate spring (only up to a 25psi spring) and tuner for my truck and run him. might be a good race
  #58
Old 02-02-2009 | 11:42 AM
Saint_Ali's Avatar
im gonna swap in a honda q72
  #59
Old 02-02-2009 | 01:01 PM
Ninja Administrator
im putting a busa motor in my TA. very light, and revs up to 15k. 1.3L of fury!!!!
  #60
Old 02-02-2009 | 01:04 PM
Saint_Ali's Avatar
what transmission should i go with ? i want one with 16 gears like those honda guys have
Quick Reply: camaro vs. audi s4 hahha
