View Poll Results: What does a platypus like to eat?
Chaotic94
8.47%
Puck90a
12
20.34%
Massey
8.47%
WIspartan1026
5.08%
nj85z28
6.78%
craby
23
38.98%
buffalo02Z28
11.86%
Voters: 59. You may not vote on this poll
Vote for April ROTM - 4th gen
Old Apr 17, 2011 | 04:58 PM
greenarrow's Avatar
September 2009 ROTM
Default Vote for April ROTM - 4th gen
Vote for your favorite 4th Gen for April 2011 ROTM.
The nominees are: In no paticular order.
Chaotic94
1994 3.4 Camaro 5-speed. I bought my Camaro two years ago and I've been restoring/modding it ever since. Check out everything that it's had done to it here in my progress thread!
Puck90a
1995 Camaro Z28, auto, stock, no t-tops
Massey
Well this is my Sarah. She is a 1999 V6 with T-tops. Her mods so far are Kenwood deck with HD radio and iPod link, rewired factory amp, ANZO Halo headlamps, BMR Tower brace, 2001 Bonneville 3800 with painted intake, Machined 3800 Series II lettering, and painted valve covers, K&N air fliter and C5 Corvette 17x9.5 rims wrapped in Nexen 3000 rubber on all 4 corners. By the time Voting starts I will have new ceramic brakes on all 4 corners with black painted rotors and calipers.
WIspartan1026
1996 Camaro Z28. T-tops, Polo Green Metallic over tan leather interior. Purchased as a project for $1000, was only running on 6 or 7 at the time. Swapped entire interior out of wrecked donor car.
nj85z28
1998 Camaro SS
LS1 V8
Tick Stage 2 T56
LS7 clutch
GMPP slave/throwout
Spohn torque arm, rear and front control arms
SLP Lid and Strut brace
craby
I bought this one in 09 and have upgraded just about everything. heres my build thread, https://camaroforums.com/forum/4th-g...1-build-42437/
buffalo02Z28
No Pic.
No Info.
Now as always you guys can do pretty much whatever you want to in order to get votes. Add a more robust description and as many photos as you want. But don't go posting threads to vote for you in every section, that's got to stay in OT.
Voting ends at midnight central time on April 30th.
Good luck to you all, now lets get it on!
Old Apr 17, 2011 | 05:34 PM
Buffalo02Z28's Avatar
2002 Camaro Z28. Auto, T-tops, Onyx Black exterior, ebony leather interior, and black powder coated C6 ZO6 wheels with red trim. Its about to turn over 100K miles!
Old Apr 17, 2011 | 06:29 PM
Puck90a's Avatar
Dominos Puck
New Formula! Now with 10% more Win!
Old Apr 17, 2011 | 06:32 PM
greenarrow's Avatar
September 2009 ROTM
Originally Posted by Puck90a
I gotta say that this is just a cool pic IMO.
And where's your mod list?
LOL
Old Apr 17, 2011 | 06:52 PM
i sent my info and picture in a long long time ago. you donkey. does this picture look familiar.
Old Apr 17, 2011 | 06:58 PM
Engine/Drivetrain Modifications:
Intake by elliotts port works
fully ported
enlarged runners
58mm tb opening
58mm bbk throttle body
LT1 LE2 heads by elliotts port works
manley 2.00/1.56 6000 series valves
patriot gold extreme springs (155 lbs seat and 400 lbs open)
205 cc intake port flow about 275/190 CFM
bullet racing cam grind #CLT276/281-12HR
223/230 .565/.565 112 separation
single roller timing chain with gears
aluminum billet oil pump drive housing
ARP 134-7103 7/16 rocker studs
Trick Flow TFS-21407100 Pushrods, 5/16 x 7.100
comp cam 1305 roller rockers 1.6 7/16 pro magnum
tpis performance roller lifters
GM performance composition head gaskets
part # 12553160 .028 compressed thickness
gm performance oil pump NAL-12555884
5.5 qt moroso oil pan 20185
arp oil pan studs 234-1901
arp main bearing studs 134-5601
moroso oil pump pickup 24212
rpc valve covers
kooks 1 3/4 x3 headers jethot coated
kooks catted y pipe jethot coated
corsa cat back with 3 1/2in. double outlets.
patc level 3 transmission with the raptor drive and and power gear upgrades
patc 5x power raptor lockup 2000 stall torque converter with a torque multiplication rate of 2.5.
derale 7 1/2x11 transmission cooler
spohn driveline
373 gears
Suspension Modifications:
koni double adjustable struts
koni adjustable shocks
spohn panhard bar
spohn crossmember mounted torque arm
spohn shock tower brace
spohn rear lower control arms
spohn subframe connectors
powerstop slotted & drilled rotors
hawks ceramic pads
strano braided brake lines
Wheels/Tires Modifications: Front 17x8.5 Billet 245x45
Back 17x11 Billet 315x35
Interior/Exterior Modifications:
white face gages
kenwood kdc-x994
kenwood kfc-c1739ie 6-3/4" 3-way speakers
pioneer ts-a1782r 6-3/4" 4-way speakers
mtx t-form 93-02 camaro black w/10" sub
okole seat covers
__________________
Old Apr 17, 2011 | 07:18 PM
Puck's car looks boring...
Old Apr 17, 2011 | 07:42 PM
greenarrow's Avatar
September 2009 ROTM
Dude, I'm so sorry! I just totally missed it when I was putting it all together. But I fixed it in the main post.
Old Apr 17, 2011 | 08:31 PM
1998camarossclone's Avatar
kinda off topic, but how do you get nominated?
Old Apr 17, 2011 | 08:39 PM
Puck90a's Avatar
Dominos Puck
Hold on... Lemme pop off some interior panels and spray paint them red.
