Vote for April ROTM - 4th gen
6 Attachment(s)
Vote for your favorite 4th Gen for April 2011 ROTM. The nominees are: In no paticular order. Chaotic94 Attachment 27253 1994 3.4 Camaro 5-speed. I bought my Camaro two years ago and I've been restoring/modding it ever since. Check out everything that it's had done to it here in my progress thread! Puck90a Attachment 27254 1995 Camaro Z28, auto, stock, no t-tops :mad: Massey Attachment 27255 Well this is my Sarah. She is a 1999 V6 with T-tops. Her mods so far are Kenwood deck with HD radio and iPod link, rewired factory amp, ANZO Halo headlamps, BMR Tower brace, 2001 Bonneville 3800 with painted intake, Machined 3800 Series II lettering, and painted valve covers, K&N air fliter and C5 Corvette 17x9.5 rims wrapped in Nexen 3000 rubber on all 4 corners. By the time Voting starts I will have new ceramic brakes on all 4 corners with black painted rotors and calipers. WIspartan1026 Attachment 27256 1996 Camaro Z28. T-tops, Polo Green Metallic over tan leather interior. Purchased as a project for $1000, was only running on 6 or 7 at the time. Swapped entire interior out of wrecked donor car. nj85z28 Attachment 27257 1998 Camaro SS LS1 V8 Tick Stage 2 T56 LS7 clutch GMPP slave/throwout Spohn torque arm, rear and front control arms SLP Lid and Strut brace craby Attachment 27258 I bought this one in 09 and have upgraded just about everything. heres my build thread, https://camaroforums.com/forum/4th-g...1-build-42437/ buffalo02Z28 No Pic. No Info. Now as always you guys can do pretty much whatever you want to in order to get votes. Add a more robust description and as many photos as you want. But don't go posting threads to vote for you in every section, that's got to stay in OT. Voting ends at midnight central time on April 30th. Good luck to you all, now lets get it on! |
3 Attachment(s)
Attachment 27250
Attachment 27251 Attachment 27252 2002 Camaro Z28. Auto, T-tops, Onyx Black exterior, ebony leather interior, and black powder coated C6 ZO6 wheels with red trim. Its about to turn over 100K miles! |
6 Attachment(s)
And where's your mod list? LOL |
6 Attachment(s)
i sent my info and picture in a long long time ago. you donkey. does this picture look familiar.
Attachment 27223 Attachment 27224 Attachment 27225 Attachment 27226 Attachment 27227 Attachment 27228 |
2 Attachment(s)
Attachment 27221
Attachment 27222 Engine/Drivetrain Modifications: Intake by elliotts port works fully ported enlarged runners 58mm tb opening 58mm bbk throttle body LT1 LE2 heads by elliotts port works manley 2.00/1.56 6000 series valves patriot gold extreme springs (155 lbs seat and 400 lbs open) 205 cc intake port flow about 275/190 CFM bullet racing cam grind #CLT276/281-12HR 223/230 .565/.565 112 separation single roller timing chain with gears aluminum billet oil pump drive housing ARP 134-7103 7/16 rocker studs Trick Flow TFS-21407100 Pushrods, 5/16 x 7.100 comp cam 1305 roller rockers 1.6 7/16 pro magnum tpis performance roller lifters GM performance composition head gaskets part # 12553160 .028 compressed thickness gm performance oil pump NAL-12555884 5.5 qt moroso oil pan 20185 arp oil pan studs 234-1901 arp main bearing studs 134-5601 moroso oil pump pickup 24212 rpc valve covers kooks 1 3/4 x3 headers jethot coated kooks catted y pipe jethot coated corsa cat back with 3 1/2in. double outlets. patc level 3 transmission with the raptor drive and and power gear upgrades patc 5x power raptor lockup 2000 stall torque converter with a torque multiplication rate of 2.5. derale 7 1/2x11 transmission cooler spohn driveline 373 gears Suspension Modifications: koni double adjustable struts koni adjustable shocks spohn panhard bar spohn crossmember mounted torque arm spohn shock tower brace spohn rear lower control arms spohn subframe connectors powerstop slotted & drilled rotors hawks ceramic pads strano braided brake lines Wheels/Tires Modifications: Front 17x8.5 Billet 245x45 Back 17x11 Billet 315x35 Interior/Exterior Modifications: white face gages kenwood kdc-x994 kenwood kfc-c1739ie 6-3/4" 3-way speakers pioneer ts-a1782r 6-3/4" 4-way speakers mtx t-form 93-02 camaro black w/10" sub okole seat covers __________________ |
Puck's car looks boring...
Originally Posted by craby
(Post 529429)
kinda off topic, but how do you get nominated?
Originally Posted by Buffalo02Z28
(Post 529438)
