2009 ROTY Baby!!!! Put Your Vote Here!!!!!
This is the big one boys and girls, it’s 2009 RIDE OF THE YEAR!!!
There are two threads set up because of the way the polls are here on the forum, where as you can only have a max of 10 poll options, but we have 11 camaro ROTM winners. So, I've split them up, 6 in one, 5 in the other. Please keep all comments in this thread and leave the others just for voting.
The ROTM winners are:
Scooch - January
Its a numbers matching SS350 Car. Factory A/C, Automatic. No big mods... Original engine bored, mild cam, Edelbrock Performer Series Intake & Carb, HEI Dist., Hooker Comp. Headers, Complete SS Exhaust... many things to come.
JRs72RS - Febuary
Numbers Matching 72 Ralley Sport. Original 350 stroked to 383. Air-Ride. 4-link suspension. Shaved door handles and custom paint.
age84 - March
1984 Z28 with a new 350 with the Edelbrock RPM Performer Heads and Intake, 750 Holley with the T5 transmission. lowered 2" in the front and 1.5" in rear.
Zoilus - April
MusicMan - May
American Racing Chrome TTM wheels, big fat tires, Strano-Bilstein shocks all around, TSP Rumbler cat-back exhaust, 4.10 rear w/ posi and disk brake conversion, fully built 3.8 v6 (blueprinted short block with hypereutectic pistons, big cam, heavy springs, ported and polished heads and intakes by yours truly). Fastest V6 on CF, as well as most modified. For complete mod list: http://www.cardomain.com/ride/3103444
brian_rs/ss - June
1968 camaro rs/ss, frame off resto by david lord, GMPP ZZ383/425, hooker super comp LT's
custom 3" true duals with magnaflow dual i/o muff, m22 4spd, 3.73 gear, 12 bolt rear end, 17" torque thrusts, BFG rubber. And i dunno if this is relevant or not but the car has NEVER seen a drop of water/rain since the frame off. it is garage kept and gets very gently washed/waxed in said garage.
bowtieguy - July
78 camaro ,.030 over 454 balanced, 510/288 comp roller,roller rockers,elderbrock highrise intake,781 steel head,headers,holley 750,flamethrower dist,400 turbo with shift kit,3.70 posi-trac,sub frame connectors and traction bars.All new interior.235/60-15 cooper cobra's on front and 275/60-15 cooper cobras on the rear,15x7 cragars front and 15x8 cragars rear.
Jr. Mechanic - August
1983 Camaro Z28 that was originally a crossfire injection car. It was factory optioned with the two tone black and gold, fiberglass air induction hood, G80 LSD rear end with disc brakes and 3:42 gears, rear wiper, leather seats, cruise control, power windows/locks/mirrors, and basically every option available.
greenarrow - September
1995 Z28 6-speed Convert. 17X9.5 corvette wheels, functional fiberglass SS hood, high rise spoiler, DG motorsports gfx, BMR STB/LCA's with brackets/Lowering springs/panhard bar. CRT alum elbow, ported/descreen MAF. Custom SS style rally's, custom tune, BBK shorty headers, magnaflow cat, flowmaster muffler, LTCC coil coversion, over the top stereo system. http://www.cardomain.com/ride/423456
Gorn -October
I bought this car with a damaged motor for 1K last year. I was my hope to rebuild the motor. A spun main bearing made repair impractical. I located a used 2002 motor from a Camaro with 48K on it. During the install I did several upgrades. The goal was to build an everyday car that would get 30 Miles per gallon highway and not boring to drive. All upgrade where done with this in mind.
Upgrades: OBX Headers, Centerforce Duel friction Clutch, Hurst Short thro shifter, Cold Air intake
Chevelle Man - November
What we have here is a 2SSRS that is 100% factory stock.
It's an R6P car (early order) equipped with the 426hp LS3 motor, 6 speed manual transmision and is covered with the amazing Inferno Orange Metallic (IOM) paint.
Other options on this car besides the RS package are ...20" polished aluminum wheels,Cyber Grey Metallic (CGM) rally stripes, factory floormats, Orange accent interior trim and a body colored engine cover.
Now as always you guys can do pretty much whatever you want to in order to get votes. But don't go posting threads to vote for you in every section, that's got to stay in OT.
Voting ends at midnight central time on December 31th.
Good luck to you all, now let’s get it on!
This is a list of modifications done to my camaro.
Performance:
Ram Billet Flywheel with Steel insert
Ram PowerGrip clutch
Aftermarket fiberglass SS style hood
SLP SS Air Box Kit
K&N rechargeable air filter
CRT Aluminum intake elbow
Ported/de-screened stock MAF
Throttle body air foil
Hypertech Power Stat 160 degree
Bosch +4 plugs
Throttle body bypass (free mod)
Flowmaster muffler with 3” inlet, dual 3” outlets
BBK shorty headers and 3" y-pipe (jethot coated)
Magnaflow 3" high-flow catalytic converter
B&M ripper shifter
Boss 250 amp alternator
March gloss black powder coated alt. fan and 10% overdrive pulley
RS sports extended front air dam (about 2” longer than stock, a must for any camaro with ground effects)
LTCC coil conversion getting finished up right now!
Suspension:
Custom shift ****/tilt lever **** from koolknobs.com (Thanks Bruce)
Power slot front and rear slotted/crossdrilled rotors
CAGS skip shift eliminator
RK sports Prothane Transmission and Torgue arm bushings
Energy suspension polyurethane motor mounts
GoodRidge SS braided brake lines
BMR lower control arms
BMR lower control arm relocation brackets (weld in)
BMR crome-moly adjustable pan-hard bar
BMR lowering springs (about 1.5" all around)
BMR SS strut tower brace
KYB 8 way adjustable struts (front) and shocks (rear)
Appearance/Other:
Black convertible top (replaced factory tan top)
Polished stainless steel Z28 badges, rear camaro letters, custom flamed front badge, and chevy bowtie.
RK sports stainless steel SS Hood Grille
Viper 5200 Car alarm with Invisi-beam Field Disturbance Sensor
High rise spoiler with LED third brake light
Stainless steel power antenna
Clear front corner turn signal lamps with amber LED bulbs
Flush stainless steel Hood Pins
RK sports stainless steel SS hood grille
Custom stereo: Kenwood Excelon KVT-X819 DVD/CD player with flip-out 7" touch screen, Kenwood KCA-BT100 Bluetooth unit and Kenwood KNA-G510 add on garmin navigation unit, Kenwood KCA-iP300V ipod adapter, 4 6.5 Rockford Fosgate 3 way speakers, 4 1" Kenwood tweeters, 2 Kenwood KFC-W3009 12" subs powered by 2 Kenwood Excelon KAC-X621 amps, and profile crossover.
Custom leather seat covers from leatherseats.com
Corvette chrome 5 spoke 17 X 9.5 rims with BFG KDWS 275/40-Z17 tires
Optima yellow top battery
3” polished stainless steel dual circle/slant cut/off-set exhaust tips
Eagle eyes LED tail lights
Clear corner signal housings with red 194 LED bulb
Custom paint (Stock green with black rally’s)
Modo innovations LLC pedal covers
Tinted windows
Green 15 LED strip in SS scoop
This pics a little older, but not much has changed.
This is what my car looked like when I brought it home almost 11 years ago.
Link to CF photo album: https://camaroforums.com/forum/members/greenarrow-15386-albums-da-z-43/
Performance:
SLP SS Air Box Kit
Bosch +4 plugs
B&M ripper shifter
Suspension:
Appearance/Other:
Tinted windows
There can be only one...... ROTY , and for this year, it's gotta be the 5thGen winner...why you ask?
This year marks the return of the Camaro and what better way to honor it's return, than to vote for it for this years ROTY.
C'mon people let's celebrate the Camaros return properly, vote for the 5th gen for the 2009 ROTY
When I was 14, I rebuilt an engine that I found behind my father's shop with intentions to drop it into a car. I bought my Z with a tired 305 for $900 when I was 15. I'm now almost 17 and still working vigorously on the car.
The engine is a 350, 4-bolt main (3970010 casting.) Mods list includes: Scat steel crank, steel rods, forged aluminum pistons, Melling high volume/pressure oil pump, double roller timing set, mild cam, Edelbrock Performer intake, Holley Street Avenger 670 Carb, shorty headers, MSD coil, Jegs high volume fuel pump, Flex-a-lite flex fan, and a few other odds and ends.
Transmission: 700R4 built by Steve at Downtown Transmission in Davie, FL. I HIGHLY recommend him. Parts include a billet input shaft, high volume oil pump, kevlar bands, kevlar coated "Z Pack" clutches, corvette servos, Transgo shift kit, 2300 stall converter, TCI lockup kit, B&M ratchet shifter, and of course a few other things.
The car: New shocks and struts, Energy Suspension Bushings, new ceramic pads/rotors/calipers all around with stainless braided lines, Aeroquip Stainless Braid Racing Hose from the tank back, Optima Red Top, Flowmaster 80 series muffler, 235/65/15 BFG Radial T/A's, Sun Pro gauges, JVC H/U with Pioneer speakers, 145mph speedometer, etc.
And a little before and after:
