BasicConcepts JDM Prelude build thread
Old Jan 15, 2013 | 12:39 AM
  #141
John4649's Avatar
I order most of my car parts from eBay I tend to save 10-65% of what napa wants and I refuse to go to autozone now and about the puck are you sure it will hold up ?
Old Jan 15, 2013 | 12:43 AM
  #142
BasicConcepts's Avatar
Technical User
I like rockauto, but I hate waiting for shipping. I have a really really good discount at advance (5-10% over there price, usually about 50% off) I also buy quite a few parts off amazon.
Old Jan 23, 2013 | 04:51 PM
  #143
Technical User
Well, shes done... sort of. I still gotta adjust the rockers, put the interior back together, and put the passenger side door back together. But i did drive it
Old Jan 23, 2013 | 05:53 PM
  #144
Technical User
My new header and down pipe
Old Jan 24, 2013 | 07:02 PM
  #145
Technical User
So the car is surging at idle, at first I thought it was the rockers but I adjusted them with no change (.007" between the rocker and cam lobe). The timing is perfect (15° btdc). Could it be because the gas is kinda old? The kid filled the tank and drove about 5 miles and blew the motor, that was back in early june.
Old Jan 24, 2013 | 09:08 PM
  #146
I really doubt it's the gas. That sounds like an air/fuel management issue, not an octane issue.
What happens when you unplug the IAC?
Old Jan 24, 2013 | 09:50 PM
  #147
Technical User
Haven't tried that, I googled "engine surging" and bad fuel was one of the suggestions. I'll try the iac tomorrow.
Old Jan 24, 2013 | 10:11 PM
  #148
I'd say the "surging" help you were finding was likely in reference to bad gas causing the engine to bog.
Yours is acting too rhythmic, like it's cycling rich-lean-rich-lean. Something there can't make up it's mind.
Old Jan 25, 2013 | 04:14 PM
  #149
Technical User
well im pretty sure this engines f****d, today i was working on the surging issue and i noticed it was smoking real bad. i checked the oil and it was gray. i drained it and it looks to be 1/2-3/4 qt too much.
Old Jan 25, 2013 | 05:04 PM
  #150
Did you rebuild the whole engine, or just work on the upper end? Did some of your coolant disappear on you?
