Back-seat Stingray
Old 05-18-2013, 01:16 AM
Might want to seriously re-think that plan....just sayin. It's not likely to end at you just doing a frame cleanup, paint the frame, and body reinstall. You can clean up a good portion of the frame with the body still on. I did mine with the car up on a lift.
  #102
Old 05-18-2013, 01:30 AM
bobarian91's Avatar
BackseatBob
You thinking a bunch of stuff will break? Ideally I will take the entire body off either way.
  #103
Old 05-18-2013, 02:04 AM
No, but yeah I'm sure you'll break something you don't want to. I've just seen a frame off turn into a can of worms before. Oh well, as long as everything is out in the open, might as well replace the rear bushings cuz they're a little sloppy, and then the rear wheel bearings, and look the rearend is leaking, and the brake lines are rusty, and the front suspension could need replacing, and then.... Meanwhile, two years later...... Heck, even some frame on projects drag out way too long. Like, my current one for instance.
  #104
Old 05-18-2013, 02:13 AM
bobarian91's Avatar
BackseatBob
Well I already planned on new suspension and bushings and body mounts and everything. It's just easier with the body off hahaha.
  #105
Old 05-18-2013, 02:18 AM
Definitely makes it a lot easier for replacing the rear trailing arm bushings. Doing those with the body on is a real beech.
  #106
Old 05-18-2013, 02:32 AM
bobarian91's Avatar
BackseatBob
Exactly. Plus I don't want to have to take everything back off in two years because I got lazy NOW. so I would rather just do it when it's in beginning stages.
  #107
Old 05-18-2013, 05:21 PM
bobarian91's Avatar
BackseatBob
OK I have decided to do the frame off. Once I finish the camaro I will start taking the vette body off. I got my wiring harness but can't pick it up til Monday. So all weekend the camaro is my project. Pics will be taken. Lots of them!
  #108
Old 05-20-2013, 10:32 PM
bobarian91's Avatar
BackseatBob
Old harness removed. A LOT of clipped wires. Mostly for courtesy lights it looks like.
  #109
Old 05-22-2013, 12:13 AM
bobarian91's Avatar
BackseatBob
Turns out, the original panels all have their proper color underneath the crappy carpet stuff. I'll post pics once I get a scraper and get all the adhesive off!
  #110
Old 05-22-2013, 09:45 PM
bobarian91's Avatar
BackseatBob
Adhesive remover is working GREAT. Top pieces are after using the remover. Bottom two are in process. Original pieces are in good shape mostly.
Quick Reply: Back-seat Stingray
