Twin Turbo 68 RS camaro..
#21
Im back,been busy...I still have to send out the stuff for coating,I came to a hault at that stage...Its been too hot here to work on it and ive been busy working,so I got the grinder yesterday,did alot of grinding on the welds and got them smooth...Im about ready to send the stuff out,then I need to plumb the oil lines and drains and hook up the fuel system....I most likely will be at Sema again ..I cant wait to have this done and drive it again,im going to have alot of fun with it that is for sure...
#22
I got the hood back from the body shop that originally painted the car in 1994(it looks perfect,cant tell all the holes that were in it from the explosion)Got the jet coating back today and started assembling the headers,turbos,wastegates and downpipes!
Should have this bolted back together by the weekend,then its off to my friends shop for the fuel connections,The duel fast wideband kit,the BTM MSD stuff connected,the oil lines into the turbos and the drains and I also just picked up a methonal injection kit from SMC....
Then its off to another friends shop to mount and pipe the 2 into 1 1000 HP intercooler(not like I need that much)...
Heres pics of the hood,its was in rough shape from the nos explosion..Its not adjusted yet,just sitting there in place..
#23
nice build.. Mine is almost done as well. I went with a twin turbo 540 EFI.. I am curious to see what kind of power our cars make. I am just installing my moser 9" right now then it's going to be tuned.
What turbos and A/R housings are you using? Cam? It's amazing how much room you have in your engine bay compared to me..
#24
Ya with the wheel wells out it make for alot more room...The turbos are PT-60-31 good for like 550hp each....Power,Well my friend local to me did a 350 with the chinese twins(in a 1976 Z28) and went 10s all over the track...My cam was a custom grind from comp cams,Solid roller...My rear end is next,my friends at www.carsbyss.com have one in stock for my car and the car is now at there shop getting wired up along with the methonal injection kit...
The jet coating turned out awesome but found I ground a bit too much on the downpipes so they are doing a few things to them and I should have them back by Friday...Im off to look at your build..
#25
Its done...Fired it up today and it sounds radical without the turbos!
This thing looks crazy under the hood now...Pics will come,but not sure anyone is even on this site anymore...wtf?
#28
Thanks,I plan on doing alot of video but we got to dyno tune it in first..
Here is a picture I took today,tommoro we have to get the mandwel bends on for the intercooler part of it,but it runs now and sounds perfect..
#29
Drove it home today...Whats the chances,finally done and nothing but wet roads..
The intercooler turned out real nice as it has its own air and isnt robbing my radiators air...Its very responsive from what I can tell in the rain and it spools FAST...Cant wait for the rain to go away!
#30
Amazing install Tommy! All that plumbing under the hood with no bluges on the hood! Looks so stock nobody would ever know if they didn't hear it!
