Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
real electric supercharger?
Old Jan 15, 2010 | 10:24 AM
rocket2050's Avatar
Default real electric supercharger?
Is there such thing as a real electric supercharger? There are alot of ebay ones which sell for $30+ and I looked at some of the seller's feedbacks and it looked like most people were satisfied about what they bought. I also googled Electric Supercharger and found one selling for $199. How would I know which one works and which one doesn't?
Thanks
Last edited by cplthomas; Jan 17, 2010 at 08:05 PM. Reason: lets see if he returns to fix it. link removed.
Old Jan 15, 2010 | 10:59 AM
Wow, it blew that teetering 2x4 over like nothing flat! Imagine how well it will help to power your pistons up and down!!! Fan rpm is one thing, cfm and psi output is another.
It's snake oil. Your engine will benefit more from something like this: Piston Return Spring
Old Jan 15, 2010 | 11:44 AM
they are a ripoff. get the same increase using just the high flow air filter. get a cai and have the computer tuned for any add ons.
Old Jan 15, 2010 | 01:26 PM
You need at least 20 to 50 HP to drive a supercharger hard enough to make a noticeable power increase. An electric motor that can produce that kind of power weighs several hundred pounds. Also a 100 AMP alternator is good for about 1200 Watt or about 1-3/4 HP, which means the battery will have to provide most of the supercharger power. With that kind of draw the battery will run out very quickly an leave you stranded
Old Jan 17, 2010 | 07:02 PM
02StanGT's Avatar
I'm going to say you are a spammer. You are new on the wrx site I am on alot, and asked the same question. Google his name and you'll see he is a "part" of alot of other forums, asking the same question.
Old Jan 17, 2010 | 08:16 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
I just bought a hair dryer that I plugged into my intake plenum, should do the same thing.... I just need a really long extention cord.
Old Jan 17, 2010 | 08:39 PM
Good idea, but if you want to use a shorter extension cord, you could put a 1500 Watt portable generator in the trunk to power the hair drier.
Old Jan 17, 2010 | 09:01 PM
gas powered leaf blower. lol.
Old Jan 18, 2010 | 12:42 AM
GMDCAMARO's Avatar
What Brand to you recommend for Optimum power increase?
Old Jan 20, 2010 | 11:16 PM
RFxCamaro's Avatar
conair its what the hair stylist use, you know of paul mitchell is using it its good
