V6 Engine Swap
V6 Engine Swap
I have a 1991 Buick Century with a 3.3 l v6. The Buick was recently rearended. The engine runs strong and has low miles. I want to find a 1988 to 1991 Camaro, hopefully an RS model with a v6. Can I make this swap?
Welcome to the Forum!! Now hit the tech sections and you'll find the answer youre looking for. everyone on this site is very helpfull. When you pick up a Camaro make sure you come back and post some pics of your swap.
Hopfully an admin will move this. Your short answer is no it will not fit. Since they never put that type of engine in a F body none of the parts you would need are around. You would have to make motor mounts the camaro transmission from those years would not bolt up, you would need a custom exhaust made also you would have to figure out where the motor should be sitting and make brakets for all your accessorys that have cleance issues. So the long answer is yes it could fit but if you have to ask the question "will it fit" chances are you do not have the knowledge to "make it fit".
