problems starting...
Old Sep 2, 2006 | 12:39 AM
larson99ss's Avatar
Default problems starting...
I have recently purchased a 1999 ss with 80,000 miles. iv driven it for a month with no problems, but just recently, its been having trouble starting. the engine is turning over but just not firing. and if i let it sit for a few minutes, then try again it fires right up. im wondering if the fuel pump is getting worn out, and am wondering how long they typically last?
Old Sep 2, 2006 | 12:31 PM
Blade's Avatar
June 2007 ROTM
Default RE: problems starting...
Well there are two things you can look at one is the fuel pump or a clogged line. I would go get some of that stp fuel system cleaner that goes in ur gas tank when u fill it up and see how that works for you. Or change out the fuel pump. your question was how long does one last one they start it go its only matter of time before they stop compleletly.
good luck
Old Sep 2, 2006 | 12:46 PM
SickSickSick's Avatar
check the filter first. Sick
Old Sep 2, 2006 | 01:08 PM
Blade's Avatar
June 2007 ROTM
yes check the filter and u can still add the fuel line cleaner.
EasternStryker
Feb 28, 2010 09:57 AM
videojunkie1986
Jun 3, 2009 06:02 PM
justingarcia947
Oct 8, 2008 12:25 AM
KrazyHobo
Nov 20, 2007 07:48 PM
jdubs1813
Nov 8, 2007 01:42 PM
