ls/lt/hemi/coyote Engine cart/stand
Old Feb 21, 2019 | 12:14 PM
MotorHeadTech.'s Avatar
Default ls/lt/hemi/coyote Engine cart/stand
ls/lt/hemi/coyote engine cart/stand
Design Features:
-Heavy Duty Urethane 4″ diameter swivel casters so they move extremely easy (unlike the import stands)
-1/4″ thick top plates and 2″ sq. 11ga. structural tube bases
-Professionally mig welded construction
-For use with manifolds or without
-For use with manual or automatic transmission
-Compact design for storage of engines, cart does not exceed the physical size of the engine itself
-Powder Coated finish for durability and good looks, COLOR: SILVER VEIN
-We use these for engine storage, assembly, mock-up, engine and transmission installs, motor plate fabrication,oil pan inspection and swap, etc.
-Designed and fabricated in our shop in the USA
NOTE: Will not fit with the C5 batwing oil pan
Fitment: LS 4.8, 5.3, 5.7, 6.0, 6.2, LS1, LS2, LS3, LS6, LS7, LS9, LT1, LT4, L33, L83, L86, LQ4, LQ9, LSX376, LSX427, LSX454, C5 C6 C7 CORVETTE, CAMARO SS, GTO, G8 GT, ETC.
Fitment: DODGE CHRYSLER HEMI ENGINES, V8 5.7, 6.1, 6.2, 6.4 motors. Challenger, Hellcat, Scat Pack, Charger, Super Bee, Demon, etc.
NOTES:
-Not all of the motor mounts bolt holes on the block will be used depending on which engine you are using.
-Will not fit the earlier 1st gen 392 & 426 Hemi engines
Where to buy?!?! (Link below)
https://motorheadtechniques.com/2018...ans-4-casters/
Dauntless
2010+ V6 Tech
17
May 4, 2011 10:12 PM
PseudoKirby
LS Series Tech
12
Mar 5, 2009 12:22 PM
Artigo
LS Series Tech
Feb 4, 2008 09:41 AM
