Low Engine temperature
Old Nov 27, 2020 | 03:43 PM
Buchananr's Avatar
Default Low Engine temperature
69 Camaro with a 350. What is the ideal engine coolant temperature? Temperature usually runs right around 160. I put a 190 thermostat in it and it didn't change. If anything it might have dropped slightly. Appreciate any advice
Old Nov 28, 2020 | 03:17 AM
Everett#2390's Avatar
Gauge or sending unit is not working correctly.
In checking s/unit, measure measure resistance to ground with wire removed.
Then as engine heats up, resistance should decrease and this reduction should show more deflection on gauge.
Old Nov 28, 2020 | 08:27 PM
On my performance builds I always test my thermostat in heated water. Over the years I have found thermostats that would stick or be inaccurate.
Zain
Sep 13, 2019 03:39 PM
CNCman
Aug 23, 2009 08:48 AM
adjg04
May 11, 2008 01:06 PM
camarorz28
Mar 3, 2007 12:33 AM
auSStin
LS Series Tech
Jul 16, 2006 03:05 AM
