95 Camaro 3.4 NEED ADVICE
Old Oct 24, 2018 | 12:24 PM
Tr3ll2x's Avatar
Default 95 Camaro 3.4 NEED ADVICE
I need help. I have a 95 camaro 3.4 v6 that runs but when driving it for a period of time it cuts off. Yesterday I drove it with no problems. The next day I drive it to work and it cuts off. Tried cranking it back up but it seems like it’s not getting fire. I have put in new coils, spark plugs, tps, crank sensor, ecm, fuel pump, and injectors . I’m also thinking it could be my ignition switch or a bad fuse box I’m not sure . I need advice.
Old Oct 25, 2018 | 07:15 PM
Stop with the parts grenades. On a car with this old of a wiring harness your more likely to cause more problems then you fix.
You need to run some tests when the car is not running correctly.
When car is not running.
Test Fuel pressure (fuel pressure gage, can be borrowed from a chain parts store)
Test for spark(spark test, can be gotten for under $10 at any parts store or Harbor freight for under $2 on sale)
Test that the injector is getting signal. (Injector noid light, Maybe they can be borrowed from the parts store. You should be able to find singles under $20)
If you have all those and compression the car should do something, if not start at least back fire and try to start. Those test will send you the right system failure. There is a very good chance this just a bad connector or wire.
Austin Bowers
Jun 24, 2017 08:54 PM
omw2000
Apr 27, 2017 05:52 PM
c928bran
Sep 15, 2014 12:14 PM
Tim24_morris
Feb 3, 2011 09:56 PM
moore953.4
Mar 25, 2007 06:46 PM
