LT1/LT4 Tech 1993-1997
z28 been sitting for 3 years
Old 08-19-2011, 01:14 PM
Grandpaswagon's Avatar
Originally Posted by dogdog130
yall think a dent puller will get that out or no
You can use a dent puller, but it would be better to use a stud welder and puller. That way you don't have a bunch of holes in the quarter panel that require welding up. Color matching will be the hardest part of that repair.
BTW - that is a fairly common location for a dent on the fourth gens. I have seen numerous similar dents on other cars in almost the exact same spot and about the same size.
Old 08-19-2011, 04:22 PM
dogdog130's Avatar
yea i have too but im trying to figer out the back end part under the light can that be replaced
Old 08-19-2011, 04:30 PM
dogdog130's Avatar
Stud Welder Dent Repair Kit
something like this
Old 08-19-2011, 05:05 PM
something like this
That will do the trick.
Old 08-19-2011, 05:39 PM
dogdog130's Avatar
what about the back light part under it
Old 08-19-2011, 07:39 PM
I believe that is made out of a plastic resin. You might be able to do a repair on it with fiberglass and some bondo, as it is a small area that is damaged. Your other choice would be to locate a good piece at a wrecking yard or buy new and just replace the whole thing.
Old 08-19-2011, 09:15 PM
dogdog130's Avatar
yea wasnt sure if it was just that one part of a whole peice
NickCopelin
06-05-2012 09:30 PM
ROWDYROB
11-09-2009 08:26 PM
sroberts
02-04-2009 01:28 PM
MARO Z86
82-92 V8 Tech
21
10-25-2008 12:57 PM
kelsroc
03-30-2007 08:44 PM
Quick Reply: z28 been sitting for 3 years
