LT1/LT4 Tech 1993-1997
wtf
Old Jun 8, 2010 | 06:57 PM
noz's Avatar
noz
Default wtf
seriously, i was on my way to smog my car and the fans stop working, i got home and i found out the fans turn on when my maf is disconnected
Old Jun 8, 2010 | 07:13 PM
That's because when you do that your system goes into open loop mode, the computer thinks something is wrong, trips the SES light (should have) and turns on the fan.
Unplugging a couple of the sensors will trip the fan.
Old Jun 8, 2010 | 07:23 PM
noz's Avatar
noz
thats why im trippped out, water pump coolant sensor are new, i checked the relays and fuses but obviously the system is working they turn on when the maf is disconnected...
Old Jun 8, 2010 | 09:26 PM
what yr.? how did you check the relays?
Old Jun 8, 2010 | 10:08 PM
noz's Avatar
noz
95 lt1 ...puttin some voltage on the relays i can hear them clik, im started to hate my car if its not one thing is another
Old Jun 8, 2010 | 10:36 PM
camaro_junky24's Avatar
do a restance check on the realy it should be 85 and 87 that are the pins u should check i believe
Old Jun 9, 2010 | 12:19 AM
noz's Avatar
noz
ok. do you know what the resistance should be, i wish i had workshop manual
Old Jun 9, 2010 | 06:04 AM
switch with a known working relay. if the problem goes away you found it. all the relays are the same except the abs one.
Old Jun 9, 2010 | 02:08 PM
noz's Avatar
noz
yea i did, i switched relays and what not im started to think and it looks like my pcm is the problem
Old Jun 9, 2010 | 03:29 PM
