LT1/LT4 Tech 1993-1997
wont start
Old 02-28-2007, 11:49 PM
muscleman's Avatar
Default RE: wont start
ok i tested the coil, ignition module, and ignition switch... i think what i found was one part of the coil is bad.. the secondary terminal? does that make sense? it is supposed to have 5000-7000 ohms of resistance and im only getting maybe a tenth of that on the machine. will changing the coil solve this problem? or could it be something else?
Old 03-01-2007, 03:34 AM
sellc's Avatar
Ummm.... What terminals are you checking ohms? Usually when checking the coil you are checking for DC voltage to be at 12volts. Your distributor puts off a wave patternand I dont recal checking the module with Ohms.
About the only thing you can check on the ignition with an ohms meter is the resistance of the plug wires unless of course you are trying to hunt down a cut or damaged wire. Even then you would have to check for power at the coil first.
What terminals are you checking?
Old 03-01-2007, 11:00 AM
muscleman's Avatar
i have a haynes repair manual and it says this is the "secondary terminal". im not really good with electrical parts or what have you, but thats what it says. and it uses ohms. it says something wierd like one of the terminals should be between 0.3 and 1.2 ohms. on this one i got about 1.1, so thats ok i guess. the other said to set the meter higher and you should get 5000-7000 ohms and i got about 600. im kinda clueless, just followin the haynes manual.
Old 03-16-2007, 04:00 AM
INTENSE_Z's Avatar
go msd its not cheap but worth it i had the same problem
Slundy12
12-11-2011 07:57 PM
Luz Hernandez
02-26-2011 09:17 PM
mjstempky
02-19-2011 01:17 PM
jpkz94
01-21-2011 01:47 PM
89Rally
05-03-2007 01:49 AM
Quick Reply: wont start
