LT1/LT4 Tech 1993-1997
Won't Rev above 3000RPM, No power
Old Nov 8, 2006 | 03:07 PM
Dan_95_Z28's Avatar
Default Won't Rev above 3000RPM, No power
I have a 95 z28, 105,000miles. It has been rebuild in the last 14,000 miles. I broke it in properly. I was getting on the freeway and I had a sudden loss of power. It started over heating a little, i don't remember exactly how much. Now (a year later) if I start it up it doesn't over heat, no white smoke from tail pipe either. It runs rough, won't rev above 3000RPM, and will not go above 35mph. It sounds like its running out of gas, then shuts down. It won't restart right away but if you let it sit. It starts later. Then goes through the same processs. ANY IDEAS?????
Old Nov 8, 2006 | 03:31 PM
LaffCo's Avatar
Default RE: Won't Rev above 3000RPM, No power
Stupid question, Is there a Check engine Light going off ?
Old Nov 8, 2006 | 04:04 PM
RSZ28SS's Avatar
sounds like your fuel pump is going out....
Old Nov 8, 2006 | 04:05 PM
RSZ28SS's Avatar
check you fuel pressure
Old Nov 8, 2006 | 04:48 PM
Is it misfiring? Check Engine Lite ON? How is the catalyst? the symptoms suggest a clogged cat.
Old Nov 8, 2006 | 05:57 PM
carguylt1's Avatar
try changing the fuel filter. If the pressure is low that mite be it it would save a whole lot of time and trouble of droping the tank and replacing the pump if that's not it. If it is the filter you may have to change it twice.
Old Nov 14, 2006 | 08:18 PM
Dan_95_Z28's Avatar
Thanks Pete. You were right. It was a clogged cat. Running ~fine~ as hell now! Thanks
pepe
Feb 24, 2020 04:33 PM
MaxTheKiing
Aug 23, 2010 03:21 AM
Swiftpain
82-92 V8 Tech
Dec 18, 2009 08:23 PM
sante65
Jun 23, 2009 08:53 PM
