LT1/LT4 Tech 1993-1997
woah ! i wonder if !!!!
Old Feb 12, 2007 | 11:12 PM
Pro_built7's Avatar
Default woah ! i wonder if !!!!
you could drop in an ls1 engine into an lt1 body / frame ?????
Old Feb 13, 2007 | 01:55 AM
95slvrZ28's Avatar
Default RE: woah ! i wonder if !!!!
Depends on how much you like modifying your frame! You can make any motor fit anywhere with enough work. Long story short, it's gonna take a grip of work to get one of mount/fit correctly. The problem arises that the LT1 is based on the origional Chevy small block, whereas the LS1 is a new, very different, block(different shape/mounting locations etc.).
Old Feb 13, 2007 | 05:56 PM
Not to mention the computer, sensors, & wiring.
