LT1/LT4 Tech 1993-1997
Winter project advice
Old Aug 16, 2010 | 11:37 AM
Grandpaswagon's Avatar
Default Winter project advice
I live in an area where driving my Z28 is really not an option during the winter. So this year I am planning on refreshing the brakes / chassis / suspension.
I want to replace the rubber bushings because they are 16 years old, and some are starting to show signs of cracking. I am on a little bit of a budget, so price is an issue. But quality is an issue as well for obvious reasons.
I am looking at the two kits below. Does anyone have first hand experience with either kit? Any pros or cons between the two? Any recommendations on other kits that I should be looking for?
http://www.rickscamaros.com/camaro-s...1993-1996.html
http://www.summitracing.com/parts/ENS-3-18130R/
Old Aug 17, 2010 | 08:43 AM
torque_is_good's Avatar
I can't tell if both kits have the same amount of items???
are you doing this on your back or do you have access to a lift?
I should do this too
Old Aug 17, 2010 | 09:07 PM
Gonna be doing this on my back in the garage. I figured that I would put the car up on stands (all four corners) and work around.
I can't tell for certain, but I think both of the kits have the same parts.
1quik4
Sep 17, 2010 10:32 PM
AV95Z
Nov 16, 2007 01:01 PM
ShawnGP
Dec 1, 2006 07:01 PM
Deezil13
Oct 9, 2006 12:30 PM
