LT1/LT4 Tech 1993-1997
window motor?
Old Nov 29, 2005 | 12:39 AM
HURSTLT1's Avatar
Default window motor?
window goes down about 3 inches..then stops...wait 10 minutes and it will go down more...does the same when it goes up...is it the track or the motor?...shouldn't the motor just stop if it's going bad...i mean it's an electric..either it works or it doesn't right?
Old Nov 29, 2005 | 05:46 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
Default RE: window motor?
motor is going bad
Old Nov 30, 2005 | 01:08 AM
HURSTLT1's Avatar
crap...i heard there's a somewhat easy way to revmove it..by drilling a few access holes...
Old Nov 30, 2005 | 11:28 AM
RatedZ's Avatar
Right before the motors die, they start to get really slow. Both of mine in my '94 are getting ready to die.
Old Dec 2, 2005 | 02:01 AM
There is a circuit breaker protecting the motor circuit. Either the motor is going bad or the window mechanisms are crusted up and hard to move. In ither case, the motor will draw too much current and trip the breker. Once the breaker cools off, power gets restored to the motor, and the cycle repeats. Regardless, you need to pull the door panel and inspect things. Check if the window works better when the door is open, adjustments may be off and the glass binding on the weather stripping.
Old Dec 6, 2005 | 12:39 AM
HURSTLT1's Avatar
actually i've noticed that it does work a lil faster if i open the door, but it does seem like it slows down like it need to cool off..thanks for the info...where is the circuit breaker located at?...
cornmuffin
Jul 24, 2014 10:22 AM
Slick6
Nov 1, 2011 10:54 PM
98sleeper
Apr 20, 2008 07:36 PM
blink18236dude
Mar 16, 2008 08:22 PM
cbk
May 20, 2007 10:49 PM
