LT1/LT4 Tech 1993-1997
will fast burn heads work on my lt1
Old Sep 27, 2005 | 02:29 AM
triumphrider68's Avatar
Default will fast burn heads work on my lt1
totally rebuilding the motor in my 93 z28 lt1. I have a 383 stroker short block and i have a set of ported stock lt1 heads but i also have a set of fast burn heads. I have read that the lt1 injection system will bolt onto my fast burns but that they are not compatible because of the lt1 being a reverse flow motor and even if they are not designed to work on a lt1 is there anyway u can make them work??
also.... i have 30lb injectors i was lookin for between 450 and 500 hp and was thinking that i would need something closer to say 36 lb injectors?? also what cam would u reccomend i have heard alot about the gm847
any help would be greatly appreciated
Old Sep 27, 2005 | 01:27 PM
Default RE: will fast burn heads work on my lt1
Stick with your LT1 heads, the fast burn heads were patterned after them and offer no real advantage over an LT1 head
Niteblaster
Jan 22, 2012 09:04 AM
NYH1
Dec 10, 2009 04:08 PM
31Bravo
Jun 4, 2008 08:54 PM
ScottD
Nov 25, 2006 09:16 PM
