LT1/LT4 Tech 1993-1997
running hot
Old Aug 1, 2005 | 06:35 PM
deang423's Avatar
Default running hot
My 96 z is running hot. I found that the fan only runs when the air is on. With the air off the fan isn't working. What could cause this? The thermostat is fine.
thanks
Old Aug 2, 2005 | 09:41 PM
67rs/ss's Avatar
Default RE: running hot
possible coolant temp sensor .... is the check engine light on??
Old Aug 2, 2005 | 11:51 PM
deang423's Avatar
no, there is no check engine light. I am leaning towards a bad relay in the fuse panel. I will try that.
thanks
Old Aug 13, 2005 | 09:14 PM
Let us know what you found, we are getting a lot of mail on overhating and fans that won't run.
Old Aug 16, 2005 | 10:28 PM
deang423's Avatar
yep, that's exactly what it was....A relay. I went ahead and changed all of them just to make sure. The fan will kick on about 240 sitting still and cut off at 217. I've heard this is how they are programmed. Just FYI.
Thanks for all your help guys/gals...
Old Aug 16, 2005 | 11:12 PM
bjames5's Avatar
I would also consider changing it to a 160 degree thermastat. This will make it run much cooler and give better horsepower.
Old Aug 16, 2005 | 11:29 PM
94Z28SHAKER's Avatar
nice car bjames, you have about the same mods as me, the hood and paint job really make it look custom
Old Sep 4, 2005 | 12:37 PM
dodgeram's Avatar
hi can you tell me where relays located got same fault on my 97 z28 which i imported to uk from chicargo
Old Sep 4, 2005 | 07:13 PM
OneSlickZ28Chick's Avatar
Yeah wheres it located and is it easy to access I am getting ready to tune up my car tomorrow anyways. My fan only works when the AC is on.
Old Sep 4, 2005 | 11:41 PM
Before you go crazy hunting for a trouble that may not exist. These cars are factory set to run hot for emission purposes.
The fans will go on whenever the AC is turned on, regardless of temperature. If the AC is turned off, the fan(s) are factory set to turn on this sequence. The primary fan (or both fans at low speed) at 225 deg., and the secondary fan (or both fans at high speed) at 232 deg. Older models turn on fans one at the time, late models turn on both fans toghether and change their speed.
A lower temperature thermostat is of little help, unless the fans turn on sooner to take advantage of earlier opening. However; the car will run cooler ad highway speeds when the air is rammed into the radiator, but will run hot when runnig slow or idling and waiting for the fans to kick in.
With the car idling, the fans should start kicking in when the temp gage is just below the red, and keep the gage from going into the red. Unless it is a very hot day, an idling engine will never get hot enough to turn on the secondary fan or switch ti high speed.
For 1993 cars there is a kit available that will turn the fans on earlier. For 1994 and newer cars the computer has to be reprogrammed.
