Wheel hop fix?
well i just went and checked. it was 28 1/2 inch on the drivers side and 28 3/16 on passenger. both tires have the same pressure. could the difference have somethng to do with it? and these are the best i could do with the torque bushing.
the bushing doesnt look right, i would take it out and see if its all tore up.
that stock or higher, what is your tire hight? the 4th gen sets about 1/4 to 3/8 in higher on the driver side so your normal there.
tires are about 24 7/8, and i should be have time to get it out tommorrow. would that bushing cause it to do that? i guess i should of said about what was happening. threw first gear its fine ( just spinning mostly) but in 2nd it feels jumpy like the tires are trying to grab but takes a sec, after that its fine. sorry for the late info of it. not sure if that helps any.
well its getting late here so i didnt check the level. i can do that after work tomorrow, but i assume that if its low it must be leaking or used? and i noticed there is a wet spot on the side of it as if something might be leaking. i have never messed with a rearend so i dont exactly know, im just guessing from how most things with fluid are.
