LT1/LT4 Tech 1993-1997
What's next?
Old Sep 6, 2010 | 12:18 PM
Swimmerboy2112's Avatar
Default What's next?
What else can I do to add some more hp (other than boost)? I have, headers, exhaust, intake, stage 2 clutch (doesn't add hp but helps put it down), intake manifold, heads, cam, (im gonna do a more agressive cam and different heads), aftermarket MAF, new pistons, 52mm throttle body, 3:43 posi rear (again helps put power down). What else can i do to add power? I need a good tune, so i'm going to do that. Anything else?
Old Sep 6, 2010 | 01:03 PM
ricer_killaZ28's Avatar
58mm ported intake manifold and a 58mm TB, larger fuel injectors. depending on the flow of the heads and how big the cam is. and of course a dyno tune if you want the best tune.
Old Sep 6, 2010 | 01:15 PM
the intake manifold i have right now is an edelbrock (i'm not sure the size), i'll up the TB. Now for heads and cams, what's a good cam for my Camaro so that i can still take it on the street but still aggressive enough to rip around at the track.
Oh and yes, i was planning on dyno-tuning it.
Old Sep 6, 2010 | 02:36 PM
Grandpaswagon's Avatar
Edelbrock sells kits that basically turn a stock LT1 into an engine comparable to an LT4. Roughly 330 hp at the crank for a bolt on application. Not bad in my book. And if your engine is still stock internally, their kit will really wake it up.
Old Sep 6, 2010 | 02:47 PM
check out lloyd elliots site, http://www.elliottsportworks.com/lt1.html , he does great setups and you can pick whatever is best for your goals.
Old Sep 6, 2010 | 05:12 PM
Link?
Great link! Thank you very much!
Old Sep 6, 2010 | 08:23 PM
Originally Posted by Swimmerboy2112
Link?
http://www.jegs.com/i/Edelbrock/350/...0002/-1?CT=999
I found it at Jegs, and I am sure that it is available at several other places as well. Just do a search for "Edelbrock LT1 performance package".
Here is an article from a couple of years ago. It is pretty good reading and really opened my eyes to what is out there for the LT1.
http://www.popularhotrodding.com/eng...age/index.html
Old Sep 6, 2010 | 09:20 PM
Thats a great kit but i have a majority of that stuff done already so it'd be a waste. :/
Old Sep 6, 2010 | 11:30 PM
edelbrock can be outperformed by most other addons for the lt1. i have an edelbrock airgap for sale. elliotts is the number one place to get headwork done. man works magic. he can also port a stock intake to flow better than aftermarket intakes. yes way better than a airgap. a tune at one of these places or at a local dyno tuner would do wonders when your done.
http://www.lt1pcmtuning.com/
http://www.pcmforless.com/index.php?...d=16&Itemid=38
Old Sep 7, 2010 | 07:52 AM
whammer3024's Avatar
ROTM Winner
there's a reason people in the 4th gen community call edelbrock "edeljunk". its a waste of your money to go with those pieces as you spend an arm and a leg and could have spent less money for more performance
