What's next?
What else can I do to add some more hp (other than boost)? I have, headers, exhaust, intake, stage 2 clutch (doesn't add hp but helps put it down), intake manifold, heads, cam, (im gonna do a more agressive cam and different heads), aftermarket MAF, new pistons, 52mm throttle body, 3:43 posi rear (again helps put power down). What else can i do to add power? I need a good tune, so i'm going to do that. Anything else?
58mm ported intake manifold and a 58mm TB, larger fuel injectors. depending on the flow of the heads and how big the cam is. and of course a dyno tune if you want the best tune.
Originally Posted by ricer_killaZ28
(Post 453018)
Oh and yes, i was planning on dyno-tuning it. |
Edelbrock sells kits that basically turn a stock LT1 into an engine comparable to an LT4. Roughly 330 hp at the crank for a bolt on application. Not bad in my book. And if your engine is still stock internally, their kit will really wake it up.
check out lloyd elliots site, http://www.elliottsportworks.com/lt1.html , he does great setups and you can pick whatever is best for your goals.
Originally Posted by Grandpaswagon
(Post 453039)
(Post 453041)
Originally Posted by Swimmerboy2112
(Post 453074)
Link?
I found it at Jegs, and I am sure that it is available at several other places as well. Just do a search for "Edelbrock LT1 performance package". Here is an article from a couple of years ago. It is pretty good reading and really opened my eyes to what is out there for the LT1. http://www.popularhotrodding.com/eng...age/index.html |
(Post 453114)
http://www.jegs.com/i/Edelbrock/350/...0002/-1?CT=999
edelbrock can be outperformed by most other addons for the lt1. i have an edelbrock airgap for sale. elliotts is the number one place to get headwork done. man works magic. he can also port a stock intake to flow better than aftermarket intakes. yes way better than a airgap. a tune at one of these places or at a local dyno tuner would do wonders when your done.
http://www.lt1pcmtuning.com/ http://www.pcmforless.com/index.php?...d=16&Itemid=38 |
there's a reason people in the 4th gen community call edelbrock "edeljunk". its a waste of your money to go with those pieces as you spend an arm and a leg and could have spent less money for more performance
