LT1/LT4 Tech 1993-1997
whats the best
Old Mar 21, 2011 | 10:56 PM
1998camarossclone's Avatar
Default whats the best
ok guys im planning on doing a LT$ hotcam. 2 things...
1.whats the best valvspring setup...ive heard double valve springs, and also ive heard LS6 springs....
2. tuning. would a stage 2 hypertec chip work? or
what would i have to do?
1993 camaro z28
lt1 350cid automatic
Old Mar 21, 2011 | 10:58 PM
Buffalo02Z28's Avatar
Don't do the LT1 Hotcam. There are better camshafts out there for that kind of money.
Old Mar 22, 2011 | 12:33 PM
what is better? and what springs should i use
Old Mar 22, 2011 | 12:58 PM
cc502 is a little better, cc503 is way better but head p&p would be advised. i like the cam & patriot gold extreme springs i got from elliotts.
Old Mar 22, 2011 | 01:07 PM
I like this camshaft if you're going for a daily driver car.
Comp Cams 07-466-8 Comp Cams ''XFI'' (Xtreme Fuel Injection) Hydraulic Roller Camshafts
Old Mar 22, 2011 | 01:55 PM
whats the best way to tune this bad boy?
Old Mar 22, 2011 | 02:46 PM
Massey's Avatar
Best way IMHO is take it to a dyno shop and let them tune the computer. Cheapest way is to use something like PCM4Less and order a new PCM with your cam, and other mods listed.
Massey
Old Mar 22, 2011 | 08:28 PM
would these work...Patriot Performance 8401 Patriot Performance LS Series Gold Valve Springs
Old Mar 22, 2011 | 10:39 PM
have a look here for the lt1. alot depends on if you are using 1.6 roller rockers. if so you will need to measure your pushrods and pick up some new ones.
Patriot Performance Valve Springs, Locks, and Retainers from Thunder Racing
i like solomon for tune.
http://www.lt1pcmtuning.com/service/
heres pcmforless
http://www.pcmforless.com/index.php?...d=44&Itemid=40
and have a look at what lloyd has for kicks
http://elliottsportworks.com/?page_id=32
davidfarah
Jun 5, 2011 04:35 PM
kdm212
Jun 2, 2009 11:25 PM
season07allday
Apr 10, 2007 05:46 PM
