whats the best
ok guys im planning on doing a LT$ hotcam. 2 things...
1.whats the best valvspring setup...ive heard double valve springs, and also ive heard LS6 springs.... 2. tuning. would a stage 2 hypertec chip work? or what would i have to do? 1993 camaro z28 lt1 350cid automatic |
Don't do the LT1 Hotcam. There are better camshafts out there for that kind of money.
Originally Posted by Buffalo02Z28
(Post 521109)
cc502 is a little better, cc503 is way better but head p&p would be advised. i like the cam & patriot gold extreme springs i got from elliotts.
I like this camshaft if you're going for a daily driver car.
Comp Cams 07-466-8 Comp Cams ''XFI'' (Xtreme Fuel Injection) Hydraulic Roller Camshafts |
whats the best way to tune this bad boy?
Originally Posted by 1998camarossclone
(Post 521314)
Best way IMHO is take it to a dyno shop and let them tune the computer. Cheapest way is to use something like PCM4Less and order a new PCM with your cam, and other mods listed. Massey |
Originally Posted by craby
(Post 521294)
have a look here for the lt1. alot depends on if you are using 1.6 roller rockers. if so you will need to measure your pushrods and pick up some new ones.
Patriot Performance Valve Springs, Locks, and Retainers from Thunder Racing i like solomon for tune. http://www.lt1pcmtuning.com/service/ heres pcmforless http://www.pcmforless.com/index.php?...d=44&Itemid=40 and have a look at what lloyd has for kicks http://elliottsportworks.com/?page_id=32 |
