LT1/LT4 Tech 1993-1997
what compression to run
Old Oct 17, 2009 | 03:21 AM
  #41
bammer's Avatar
Unhappy
Originally Posted by 383Stro
wrist pin failure 38lbs with a creep.
dude that sucks. was the block salvageable?
Old Oct 17, 2009 | 12:44 PM
  #42
z28rob18's Avatar
get a photobucket account then use that to post onto here
Old Oct 17, 2009 | 07:58 PM
  #43
383Stro's Avatar
or just upload them from your saved pictures as attachments where it says manage attachments. The block is fine, the rod is ovalled along with the piston where the wrist pin goes...oh well if u aint breaking u aint racing hard enough. The larger wrist pins are in already and i went with stainless rings this time because the chrome rings were chipping. The side of the pistons was in great shape and the burn area was perfectly center on the piston, so I know i had the air/fuel ratio perfect.
Old Oct 18, 2009 | 03:32 PM
  #44
bammer's Avatar
i ordered my short block to day from cooks engine performance. he is going to build it for my turbo application. 4 bolt main h beam rods dished pistons bogger rod bolts for just 3500. can't wait but it will take a while 2 to 3 weeks for the build and then he has to send it to hawaii for me. that shop has awesom customer service i did not talk to an operator i talked directly to the owner. he is also going to get my pcm programmed for me.
Old Oct 18, 2009 | 04:28 PM
  #45
z28rob18's Avatar
cool sounds good
Old Oct 18, 2009 | 05:30 PM
  #46
bammer's Avatar
i tried to get the pics from photobucket but it shows an x no pic.
Last edited by bammer; Oct 18, 2009 at 07:11 PM. Reason: can't get the pics to load from photobucket.
Old Oct 19, 2009 | 02:29 PM
  #47
z28rob18's Avatar
you have to copy the direct link then put it where it says insert image here which is the letter looking thing its yellow with mountains.
Old Oct 19, 2009 | 09:28 PM
  #48
bammer's Avatar
http://photobucket.com/bammer1975 here are some of the pics. will take more tomorrow
Old Oct 19, 2009 | 09:43 PM
  #49
z28rob18's Avatar
looks pretty good is where the flange is where the turbo will be mounted?
Old Oct 20, 2009 | 01:27 AM
  #50
bammer's Avatar
yes that is where the turbo is going to mount. i just need to gut the a/c and heater core. the driver side is going to lose the abs. going to start on that tomorrow night. will have more pics tomorrow.
