LT1/LT4 Tech 1993-1997
Water Pump Drive Groove
Old Jan 13, 2012 | 12:37 PM
NorthernCrew454's Avatar
Default Water Pump Drive Groove
Is there suppose to be a groove in the water pump drive shaft where the seal from the chain case cover rides?
Old Jan 13, 2012 | 12:56 PM
No there isn't. Was yours leaking oil?
Old Jan 13, 2012 | 01:24 PM
BasicConcepts's Avatar
Technical User
you can pull the shaft out and flip it around its the same on both ends and the seal wont be on the groove
Old Jan 13, 2012 | 01:37 PM
^ That ain't gonna do anything. The seal rides on the splined stubby shaft that's sticking out of the timing cover, not on the external connecting shaft.
Old Jan 13, 2012 | 04:26 PM
Technical User
ohh ya your right
Old Jan 13, 2012 | 07:18 PM
I cant recall its been a while since the engine was in the car. I just want to make sure there isnt suppose to be so i can fix it.
Old Jan 14, 2012 | 08:46 AM
there will be a slight grove. you can get a new drive gear. i did. part number 10128338 kind of spendy GM Parts Direct: Your direct source for Genuine GM Parts
Old Jan 14, 2012 | 09:25 AM
Something I didn't pay attention to when I changed my seal (didn't have a wear groove to compare to), the new style replacement seal is different from the factory style. The lip on the new might be riding in a different spot than the old one was.
See if this helps you, for placement reference: https://camaroforums.com/forum/lt1-l...als-94z-43601/
engin70
Apr 27, 2013 09:20 AM
rwing7486
Sep 16, 2012 07:48 PM
NorthernCrew454
Sep 15, 2011 01:48 PM
1998camarossclone
Aug 1, 2011 09:36 PM
asilomar
Sep 5, 2006 12:20 PM
