LT1/LT4 Tech 1993-1997
water pump drive removal
Old Sep 5, 2006 | 03:08 AM
asilomar's Avatar
Default water pump drive removal
I'm having some trouble getting the timing set replaced on my '94 motor. I will be picking up a 2 or 3 claw puller for the crank sprocket tomorrow. However, I can't find any good info on how to pull the water pump drive to replace the seal. My Helm's manual indicates a GM tool to use but has no diagram of it or how to use it, so I don't have any idea what type of alternative tool I could use to remove the drive. Any info or pics would be great. Thanks.
Old Sep 5, 2006 | 12:20 PM
uncle bill's Avatar
Default RE: water pump drive removal
I don't think You remove the drive to replace the seal. The drive comes through the timing cover so replace that seal also.
engin70
Apr 27, 2013 09:20 AM
NorthernCrew454
Jan 14, 2012 09:25 AM
NorthernCrew454
Sep 15, 2011 01:48 PM
1998camarossclone
Aug 1, 2011 09:36 PM
91_Camaro_RS
Feb 3, 2009 06:14 AM
