LT1/LT4 Tech 1993-1997
vacuum line to blower control
Old May 8, 2006 | 04:10 PM
jbassiii's Avatar
Default vacuum line to blower control
My 1994 Z28 has lost its vacuum to the AC/heater/defroster blower control. I haven't been able to find the leak. No lines appear to be broken or loose but I am not really familiar with how it comes off of the manifold. I was wondering if there is a good source for a diagram on how the vacuum lines are routed? And where is a common location for this type of problem to occur?
I have checked under the dash. But I'm guessing the problem is under the hood.
Old May 8, 2006 | 06:36 PM
SickSickSick's Avatar
Default RE: vacuum line to blower control
A Simple Way To Find The Leak Is To Disconnect The Vacuum Lines One At A Time From The Manfold Tree. If The Idle Doesn't Change On One Trace That One Down. It's Probably The One With The Leak. Sick
Old May 18, 2006 | 04:11 PM
jbassiii's Avatar
The leak turned out to be in a 3 way vacuum line connector next to the PCM before the line goes through the firewall. The cracks were so small that I missed them at first, but were visible when I threw on the "cheaters". I temporarily fixed the problem with silicone. I haven't been able to find that connector on line, so will be going to the dealer soon. And there is a vacuum line diagram on the spec sticker next to the radiator.
Z28Camaro98
LS Series Tech
10
Jun 3, 2012 06:52 PM
iLL95
Dec 13, 2011 02:25 AM
iLL95
Oct 4, 2011 09:25 AM
gfrench
Nov 5, 2010 08:06 PM
Jr. Mechanic
Oct 6, 2009 02:47 PM
