LT1/LT4 Tech 1993-1997
Upgrade Opinions
Old Sep 22, 2010 | 11:31 AM
gagger84's Avatar
Default Upgrade Opinions
Hey guys, I need some opinions on what to do next with my '95 Z. I was originally going to start some suspension work, but after coming across a few things on the internet, I'm not sure I need to go in that direction just yet. Now, my Z has 134,xxx miles on it and I don't know if the coils or shocks have ever been replaced, but I did the "self tests" and the shocks and coils seem fine. The car settles back into resting place after a bounce or a bounce and a half and there is no sag or bottoming out (unless I have to male adults in the back on a steep driveway). I also didn't notice any oil leaking from the shocks. There is some creaking from what I'm guessing is the coils and a some squeaking from the rear suspension when I hit some rough road, but besides that, it's a pretty smooth ride. So what do you guys recommend I do?
Should I go all out on the suspension like I originally planned and replace the coils, shocks, panhard rod, sway bar, etc? Can I get away with just doing one; either the shocks or coils? Or can I go a complete different direction for now? I was thinking of getting a SS hood and a Moroso CAI. I currently have a budget of about $750-$1000. Any advice would be much appreciated! Thanks guys!
Old Sep 22, 2010 | 11:52 AM
you could easily blow most of that on some koni shocks and struts. i would go with quality shocks and struts and a cai. what exhaust do you have?
Old Sep 22, 2010 | 11:58 AM
gagger84's Avatar
I was leaning towards getting some KYB AGX shocks or some Bilstein shocks along with rear control arms and a cai. I currently run Magnaflow exhaust.
Old Sep 22, 2010 | 12:04 PM
sounds like your on the right track. check out the tie rod ends and ball joints while your in there. changin them made a big difference on mine..
Old Sep 22, 2010 | 12:08 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I bought a package deal on ebay that consisted a set of 4 vogtland lowering springs and gabriel shocks for around $300. It made the car sit with a good stance and looked/handled better.
Old Sep 22, 2010 | 12:09 PM
gagger84's Avatar
Since I don't think I can completely afford the Koni shocks, what other ones would you recommend? How about between adjustable and non-adjustable shocks? I did have the tie rods and ball joints replaced recently so those should be good to go... Thanks again for the help!
Old Sep 22, 2010 | 02:16 PM
i love my knoi's and they are adjustable. strano has some modified shocks that are good suff. they just came out with the koni double adjustable shocks where it adjusts the recover as well as the shock control so i was kinda bummed when i seen that but still happy so far with single adjust.
Old Sep 23, 2010 | 07:51 AM
whammer3024's Avatar
ROTM Winner
i have the kyb's you mentioned..i like them
Old Sep 23, 2010 | 10:51 AM
gagger84's Avatar
What do you guys think of Bilstein HD shocks?
CountTripula
Feb 12, 2014 10:18 AM
Eagle564
Aug 30, 2011 01:48 AM
Gordon24Camaro
May 16, 2009 01:03 AM
JaySan
LS Series Tech
Apr 26, 2008 10:25 PM
cheever1804
Nov 18, 2006 05:25 AM
