LT1/LT4 Tech 1993-1997
underdrive pully
Old Nov 16, 2009 | 11:43 PM
murderd96z28's Avatar
Default underdrive pully
i was thinkin about getting an underdrive pully and was just woundering if they were worth it? like this one http://www.lmperformance.com/3665/2.html
Old Nov 17, 2009 | 06:35 AM
i think of these kind of mods as final mods. only get minimum hp gain but when uve done all the big gain mods, thats all thats left.
Old Nov 17, 2009 | 06:58 AM
blackz87's Avatar
Replacing the stock pullies on a street driven car is asking for problems. Also the gains are so small it is not worth it, in my opinion......
Old Nov 17, 2009 | 07:20 AM
The LT1 engine uses a gear driven water pump, and the underdreive pulley will do nothing for it. The water pump is a power waster at high RPM because it moves more water than needed. The other acessories, such as alternator, AC compressor, & power steering pump, only use as much power as they need. Invest in an electric water pump instead, as its operation is not affected by engine speed.
Old Nov 17, 2009 | 08:55 AM
The only problem with putting on an electric water pump, is it will put more of a load on the alternator, causing it to drag the engine down more.
Frankly, I don't think the small gain (if you will end up with one) of an underdrive pulley system is worth the expense.
Old Nov 17, 2009 | 11:07 AM
You are right, the electric pump will add load to the alternator, but it won't be as high as that of the stock pump when the engine is all wound out. IMO unless you are strictly into racing, the whole idea is not worth the time and money, as it will only gain very few horses.
Old Nov 17, 2009 | 05:28 PM
well alrighty then.. thanks guys you answered it for me
Pacop1105
Jul 13, 2011 09:44 PM
jon_uscg2001
Mar 29, 2011 02:36 PM
CamaroDreamer
Feb 18, 2011 09:00 AM
Kraiger
82-92 V8 Tech
Dec 17, 2009 06:37 AM
buddywackos
Oct 6, 2008 09:26 PM
