LT1/LT4 Tech 1993-1997
Tuning
Old May 4, 2007 | 03:30 PM
iceman11190's Avatar
Default Tuning
What would be a good tuner? For my 1996 camaro z-28?
Old May 4, 2007 | 09:07 PM
uncle bill's Avatar
Default RE: Tuning
What do You mean, A reprogammer ? Not sure here.
Old May 4, 2007 | 10:43 PM
Default RE: Tuning
I'm looking for a tuner after I would install heads and air intake, and exhaust.
Old May 4, 2007 | 11:21 PM
JD1969's Avatar
Default RE: Tuning
The best is to go a shop and have it dyno tuned with a program called LT1 Edit.
Old May 5, 2007 | 07:13 PM
95slvrZ28's Avatar
Default RE: Tuning
PCMforless.com
Old Jul 2, 2007 | 07:05 PM
rayski's Avatar
Default RE: Tuning
any one having problems tuning with a ostrich emulator.i am new to this device. the problem i am having is the emulator and ecm are not making changes to the car.
Old Jul 2, 2007 | 09:15 PM
Default RE: Tuning
Your car has an OBD2 PCM using flash memory, as far as I can make out your device works only with OBD1 ECM. But I could be wrong. What exactly were you trying to do? Be careful not to scramble up the PCM. There are certain routines that must be left alone, if the code is damaged the PCM won't respond anymore and you wind up buying another one or paying a GM dealer with a Tech 2 tool to reset it. Either way it is expensive.
maudyZ28
Dec 13, 2010 03:11 AM
Vanderkooy325
Dec 4, 2010 07:03 PM
fastZ
Feb 27, 2010 07:15 AM
stinkyparp
82-92 V8 Tech
Nov 23, 2007 11:54 AM
Saint_Ali
Nov 21, 2007 11:21 AM
