LT1/LT4 Tech 1993-1997
Transmission Woes could be the Cat?
Old Aug 28, 2009 | 12:33 AM
Marty's Avatar
Question Transmission Woes could be the Cat?
Hey Guys, my 95 Z28 is acting like it has transmission problems and is making a vibration between 1st and 2nd gears. It definitely feels like it is slipping when you step on the gas hard. A friend suggested that a plugged catalytic converter may be the problem and causes the vibrations and transmission problems. Anyone ever heard of this? I am not aware of this....please help.
Old Aug 28, 2009 | 12:51 AM
nope...
Old Aug 28, 2009 | 06:56 AM
The cat has nothing to do with the transmission. Your transmission needs help.
Old Aug 28, 2009 | 07:35 AM
Unless you have a real cat wedged up above the torque converter? But the cat converter wouldn't be causing transmission slippage problems!
Old Sep 4, 2009 | 01:16 PM
1994lt1z28's Avatar
Default cat problem
The same was happening to my 94 z28 I thought the trans was gone. I took it to the shop and my cat was just eaten up I got the cat removed. since then I have noticed a huge difference in power and in the way my car rides. just take the cat out of the pipe it sounds a hole lot nicer.
Z28Camaro98
Sep 18, 2012 10:04 AM
CrimsonRevolver
Feb 25, 2012 06:32 AM
x01660
Apr 27, 2011 07:56 AM
bayman88
Jan 1, 2010 11:11 PM
hard times
Apr 26, 2009 07:31 PM
