LT1/LT4 Tech 1993-1997
Top End
Old Jan 19, 2007 | 10:10 PM
jswizzle123's Avatar
Default Top End
Well i finally got my new edlebrock performer heads in and my car runs great but it seems that i have lost some of my low end power and gained a lot of top end is that normal when replacing stock heads ?
Old Jan 19, 2007 | 10:37 PM
toml14's Avatar
Default RE: Top End
Its really hard to say. It all depends on the specs of the heads you bought. Different combinations offer different rpm range power(ie valve sizes, intake runner ccs, chamber sizes, etc.). Installing a lower gear set will really make you notice the power increase (if it comes alive at higher rpms). I did heads on my truck motor and the difference over stock was unreal.
[/align]
Old Jan 20, 2007 | 12:04 AM
Saint_Ali's Avatar
Default RE: Top End
did you install a cam and roller rockers with the heads ? what better gears ?
Old Jan 20, 2007 | 12:59 AM
Default RE: Top End
no cam and no roller rockers and stock 2 73 gears i believe
Old Jan 20, 2007 | 01:21 PM
Default RE: Top End
If you put on heads with larger port sizes it will reduce the air velocity at low RPM, which in turn reduces the cylinder fill, which results in less low end torque. You can remedy this by installing fatter rear end gears, such as 3.70 or 4.11. This will get thelow end back and liven up the car through the RPM range. At this point you should put in a hotter cam to take advantage of the head's potential.
Old Jan 20, 2007 | 07:52 PM
Default RE: Top End
that makes a lot of sense , thanks for the help!! im so glad i joined the forum!!
