LT1/LT4 Tech 1993-1997
timing cover
Old Jan 30, 2011 | 06:50 PM
LT1ChevyBoy's Avatar
Default timing cover
This might be a dumb question but how do you remove the timing cover i dont have my book yet?
Old Jan 30, 2011 | 10:16 PM
gota take the belt off, drain the cooling system, take the water pump off, take the opti off, take the balancer off, losen the bolts on the oil pan, take the front oil pan bolts out so the front will drop, take the front cover off. if i didnt drop the pan a bit i couldnt get the dang thing to seal, taking the cover out and trying to squeeze it back in wouldnt work for me.
Old Jan 31, 2011 | 06:29 AM
torque_is_good's Avatar
is the engine on a stand or in the car?
If in the car, and you want the cover all of the way off, then you also need to pull the hub, lift the engine a little (since you are loosening the oil pan then a hoist is best) and what craby says covers it. You will end up tearing apart the gasket. If you also want to replace the oil pan gasket it can be done. I will now install my flame suit.
Simply snip the gasket on the middle of the drivers side, work the gasket around and rtv where you made the snip....it won't leak.
Old Jan 31, 2011 | 09:47 AM
its actually on the stand i will post all the pictures i can soon torque is good so you can see the project you helped me out with earlier. I managed to find a motor with wiring alternator power steering and computor for 400 i just had to drive 250 miles to get it lol
Old Feb 3, 2011 | 02:04 PM
ChandlerMotorsports's Avatar
Former Sponsor
Make sure you don't give the opti a bath. Its game over then!
lynchingacers
70-81 V6/I6 Tech
10
Oct 5, 2010 10:37 PM
lynchingacers
70-81 V8 Tech
Jun 27, 2010 07:48 PM
r6rider
Feb 15, 2010 01:35 AM
scottlee1
Apr 22, 2008 11:57 PM
