LT1/LT4 Tech 1993-1997
timing
Old Mar 23, 2007 | 02:58 AM
muscleman's Avatar
Default timing
how do you adjust timing on a 94 Z with the opti-1?
Old Mar 23, 2007 | 04:35 PM
Default RE: timing
Very carefully! Seriously, the timing is computer controlled, there is no manual adjustment possible, but it can be done by reprogramming the PCM. The PCM advances timing till it gets a knock signal from the Knock Sensor, and then backs the timing off a bit, if it sees no more knocks it advances the timing a bit. Keeps doing this till the timing is advanced just below the knock level. So there is really no need to mess with the timing. Also automatically adjusts for different octane ratings.
Old Mar 23, 2007 | 04:56 PM
muscleman's Avatar
Default RE: timing
thx for the reply... i was wondering if you can maybe delay or retard the timing slightly.. just an idea a friend of mine and i had, to make it sound a little meaner, or if i ever get my 100 shot hooked up... just an idea..
Old Mar 24, 2007 | 02:28 AM
carguylt1's Avatar
Default RE: timing
If you get that NOS system get the controler with it it will adjust the timing and fuel.
old hoon
67-69 V8 Tech
Jan 23, 2014 11:51 AM
ScottD
Mar 18, 2010 12:36 AM
adirtypoostick
82-92 V8 Tech
Nov 30, 2008 09:19 PM
87 rag
82-92 V8 Tech
Aug 5, 2008 11:49 PM
vabeachxj
82-92 V8 Tech
13
Jul 13, 2008 10:59 AM
