LT1/LT4 Tech 1993-1997
Time for an oil change !
Old Mar 15, 2010 | 03:45 PM
  #31
Don't get paranoid. With old oil comes viscosity breakdown. It's not uncommon for new oil to give you a little higher reading than the old bad oil did.
Old Mar 15, 2010 | 04:56 PM
  #32
Turbolag86's Avatar
Thanks for the advice osduck5 and Camaro 69. That makes me feel better. Now all I have to do is check the differential fluid.
By the way osduck5 I like your story about putting 5 qtz in while on the phone and the oil coming out...Haha....Sounds like something I might do when my mind starts to wonder.....I Made extra sure that the drain plug was in before I put the oil in !
Old Mar 15, 2010 | 09:47 PM
  #33
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Originally Posted by midrange
thats not what i meant cpl. I didn't mean too much in the engine block. i meant too much when doing the project.. it would suck to add all your oil to find out its still not full. i means its never hurts to over rate how much you need instead of falling short and having to WALK to the store to get more cause there is not enough oil in your motor to start it with out risking it.
Oil change.. Jack, drain, remove filter.. fill new filter up with oil, make sure new oil filter rubber seal is wet with fresh oil, put new filter on, replace drain plug, fill with oil.. done. takes 10-15 minutes..
I see what you mean now.. my bad.
Old Mar 16, 2010 | 09:55 PM
  #34
Stillborn's Avatar
I'm currently using m1 but has anyone used Royal Purpe? And what where ur thought on it, is it any better?
Old Mar 18, 2010 | 09:15 AM
  #35
Turbolag86's Avatar
I always wanted to try Royal Purple I would also like to hear reviews on it.
Some people say oil is oil... others say ...it isn't
here is an example..... Say you have four different protein powders. Product A, B, C, and D. Even though each product has a different name, they could all have contracts with the same company that produce the protein powder. So in theory, if product A cost 5 dollars more than product C, B, or D, you are paying 5 dollars more for the exact same product.
JG69
Jul 30, 2013 03:41 PM
pheonix782
May 9, 2012 06:59 PM
Spartan66
Jan 17, 2008 01:31 PM
00camaro00
LS Series Tech
Apr 22, 2007 11:21 AM
