LT1/LT4 Tech 1993-1997
Throttle control/traction control
Old Apr 17, 2008 | 10:37 PM
Combat_Chuck's Avatar
Default Throttle control/traction control
I have a 1996 Z28 and it has recently had an issue with the throttle control (that's what I'm calling this aprticular aspect of the traction control since the traction control also inclused braking). If you've ever made the wheels slip with your traction control on you will have felt how the gas peddle will feel different while the vehicle is trying to correct. I think that the clutches or whatever make the traction control module (on top of drivers side valve cover) have worn out and do not return to normal properly. What this causes if my pedal to permantantly feel like it does when the wheels slip with traction control on. it's pretty hard to explain so hopefully you guys know what I'm talking about.
Basically I'm very sure that the traction control motor/module needs to be replaced and the dealership says it's going to cost $840 JUST FOR THE PART!!!!!! has anyone else had this problem? or had anyone else replaced that part? Would a wrecking yard have it for around $200 or would it still be like $600? how about a used one?
Old Apr 19, 2008 | 11:03 AM
Default RE: Throttle control/traction control
just found one on ebay with everything involved with traction control included for $45!!!!! I am happy!
typip111
Jul 21, 2011 07:38 PM
02CamaroV6
Oct 2, 2008 06:34 PM
hotz28camaro
Feb 6, 2008 12:40 PM
KoRN_Munky
May 31, 2006 01:30 PM
codyhcahoon
May 9, 2006 09:37 PM
